190
OxygenOS Open Beta 4 for OnePlus 6
  1. B_Wrath
    Nougat Oct 1, 2018
  2. YellowClaw
    Honeycomb Oct 1, 2018
    YellowClaw , Oct 1, 2018 :
    exactly
  3. YellowClaw
    my phone's dead in 11 hrs lol, usage matters.
    B_Wrath likes this.
  4. YellowClaw
  5. rajeshkumar_r
    Froyo Oct 1, 2018
    rajeshkumar_r , Oct 1, 2018 :
    My phone usage is less and I will use it only for important calls during work. Also it will be idle without any WiFi or internet connectivity. SOT is around 3 hours as of now. This stats is good or any issue?
  6. YellowClaw
    it is good. Nothing is issue. The device is giving its best performance!
    kgerolio likes this.
  7. rajeshkumar_r
    Froyo Oct 1, 2018
    Oh great, thanks for your response. However when it comes to my old device (OnePlus 3) with 3000mAh battery of 2.2 years old, this new device gives me the same performance with 3300mAh and I'm bit concerned on this if it's good or not.
  8. YellowClaw
    offcourse ! the devices varies, new phone with new features, can't compare it with 3, over that use your phone till its dead fully, and charge it till its 100%.
    rajeshkumar_r likes this.
  9. kbishnoi
    Cupcake Oct 1, 2018
    kbishnoi , Oct 1, 2018 :
    Hello Team,
    After a long time, I just bought a new Android Phone. I'm using the Android device first time. I bought one plus 6 just because I wanted to access multiple parallel apps. before the recent system update device was working fine.
    just after the update not able to access parallel apps properly. both WhatsApp are fetching same data and login automatically. I can't use two different number it can say able to run two WhatsApp.
    Can I restore my device to previous version. ????
    I'm not happy with the UI as well, Contacts & Interface of many apps has been changed.
    HOW can I use two WhatsApp now??
    settings>>utilities>>parallel apps I enabled this then reinstall WhatsApp but can't access. when I install & configure WhatsApp 1 automatically it is fetching data into 2.
    I'm using Android phone first time. I'm a software engineer myself. tried possible options but not getting the solution.
    please help.
    I'd be happy to restore to previous version. I have restarted device as well.
    I want expert developer to guide me.
    thanks
  10. rikinroxz
    Eclair Oct 1, 2018
  11. Artemus.
    Community Hero 2020 Oct 1, 2018
    Artemus. , Oct 1, 2018 :
    Of course it does.
    W1534280953342 likes this.
  12. rikinroxz
    Eclair Oct 1, 2018
    rikinroxz , Oct 1, 2018 :
    is it normal or has any issue...is there any affect on phone?
  13. Artemus.
    It's normal, yes. The camera sensor generates heat (more so shooting 4K) while in use and therefore will feel warm while recording for long periods of time. Any effect on the phone? Probably minute depending on how long you ignore it for.
  14. kgerolio
    Cupcake Oct 1, 2018
  15. sgmtnbike
    Gingerbread Oct 2, 2018
  16. Ryanf78
    Ryanf78 , Oct 2, 2018 :
    this is what I got.
  17. sgmtnbike
    Ryanf78 likes this.
  18. Ryanf78
  19. Jhester1967
    Donut Oct 2, 2018
    Jhester1967 , Oct 2, 2018 :
    mine doesn't give me that option????
  20. avslanch707
    Honeycomb Oct 2, 2018
    avslanch707 , Oct 2, 2018 :
    [e]1f632[/e][e]1f632[/e]. shhhs... don't show this screenshot to some of the users on this forum... and or else we will have millions of thread about why they aren't hitting numbers like this.
    Ryanf78 likes this.
