190
OxygenOS Open Beta 4 for OnePlus 6
  1. Ryanf78
    Gingerbread Oct 3, 2018
    Ryanf78 , Oct 3, 2018 :
    are you using a USB C to headphone adapter? if so I believe because the OnePlus has a headphone jack the USBC Port is not optimized for those adapters only works with the headphone jack.
    F_S_Brian_Moore_ likes this.
  2. Joemtz70
    Froyo Oct 3, 2018
    Joemtz70 , Oct 3, 2018 :
    I'm using my USB cord into my car stereo USB and it won't work
  3. Ryanf78
    your car doesn't have a headphone jack or Bluetooth. you're not going to get audio over USB cable.
  4. Ryanf78
    phone is not setup to allow audio thru the USB port. also if you use Bluetooth 5.0 it sounds amazing with it's aptx hd capability. just as good as wired connection maybe even better in certain situations.
  5. OnePlusTejasred
    Froyo Oct 3, 2018
    mycatisajoker likes this.
  6. Joemtz70
    Froyo Oct 3, 2018
    why is that iPhones work and not op6? my old Android worked
  7. Ryanf78
    because the OnePlus 6 gives you a headphone jack. therefore OnePlus 6 does not enable the USB C port to produce audio. there's really no reason to use it for that. most people use Bluetooth or wired headphones not sure why you care so much that's the way it is pick one of the other two options how many audio output options do you need.
    F_S_Brian_Moore_ and Artemus. like this.
  8. cas8180
    Ice Cream Sandwich Oct 4, 2018
    cas8180 , Oct 4, 2018 :
    I am yes it is definitely worth it especially for the front facing camera. massive difference in IQ.
  9. Ryanf78
    Gingerbread Oct 4, 2018
    Ryanf78 , Oct 4, 2018 :
    um, question? I was going to try Google camera again to see what I think about it again, give it another try .. but when I go to the play store I can't find it.. not sure why. any thoughts or insight on this? is any else having problem finding the app now? I'm on beta 4? thanks.
  10. cas8180
    you got to grab it from XDA. just go to the op6 forum then apps section and you will find it there. should be it the first post.
  11. Artemus.
    Community Hero 2020 Oct 4, 2018
    Artemus. , Oct 4, 2018 :
    The Google Camera isn't on the Play Store because it's a modded/ported APK by a guy named Arnova8G2.
    Xcutioner and Ryanf78 like this.
  12. Ryanf78
    ok cool I was going to check them out. still not sure why it's not available from Google.. thanks.
  13. Ryanf78
    ok. cool thanks. do you use Google camera? or one plus camera? which one u like better and why,?
  14. Artemus.
    I used the GCam a few times, took good images. But considering I'm not a photographer, it doesn't matter to me which is better. Hell, I can't even take a steady shot to save my life.
  15. Ryanf78
    I just tried G camera. actually is much better as far as sharpness. but I really like OnePlus layout much much better than Google. also I'm sure the pictures use to be much sharper on earlier software. it was almost too sharp. now it seems to be not sharp enough. hopefully one plus adjust this next update.
  16. paulviado420
    Eclair Oct 4, 2018
    paulviado420 , Oct 4, 2018 :
    have you tried enabling otg first on the op6 ? worked for me on my basic Kenwood headunit with usb ..
  17. Ryanf78
    don't you need the OTG dongle for that?
  18. paulviado420
    Eclair Oct 4, 2018
    on the op6 it's part of the toggles you just enable it so that it can be recognized as mass storage to be able to talk to your op6 ..I can confirm it works for me on my headunit using a USB a to c cable and the headunit recognizes it so I can play music off my phone.
  19. Ryanf78
    ok. that's cool. but don't know why they sell a OTG adapter then for the op6. I figured u still needed that even but then also had to turn that feature on in the settings. I thought I was some kind of security feature they had..
  20. paulviado420
    Eclair Oct 4, 2018
    nope you don't need that but otg is off by default on the op6 you'd have to toggle it on. I use a USB c thumb drive to transfer files to and from the device and I always have to toggle it on cuz I have the setting on where it disables it after 10 mins of inactivity
    F_S_Brian_Moore_ and Ryanf78 like this.
