189
OxygenOS Open Beta 4 for OnePlus 6
  1. zoran81 Jelly Bean Oct 11, 2018
    zoran81, Oct 11, 2018 :
    No
  2. Prathamesh25 Donut Oct 11, 2018
    Prathamesh25, Oct 11, 2018 :
    problem with the fp scanner especially when the phone is in sleep mode for a long time. the fp scanner does not register but is fine after waking the phone up
    bojler, qvert and yarda like this.
  3. A1522333747845 Cupcake Oct 11, 2018
  4. YellowClaw Honeycomb Oct 11, 2018
    zoran81 likes this.
  5. B_Wrath Lollipop Oct 11, 2018
    B_Wrath, Oct 11, 2018 :
    You don't read the pinned thread and the FAQ in it... Do you???
    Are you on beta or on stable build ??
  6. B_Wrath Lollipop Oct 11, 2018
    You are a honeycomb and you still don't know where to ask feature request...
    And why not use a third party app to do this???
    Kytharsis and YellowClaw like this.
  7. YellowClaw Honeycomb Oct 11, 2018
    YellowClaw, Oct 11, 2018 :
    this is the 3rd time i am facing the black screen issue, i can go to the lockscreen but nothing works after unlocking my device. What can be the issue ? I tried wiping cache, rebooting device, clearing ram, and booting in safe mode. Never got any issues in safe mode. I tried updating even all application in case one of em was a problem. But can't find the culprit. Your advice is much appreciated. Thanks.
  8. B_Wrath Lollipop Oct 11, 2018
    Clear cache of the launcher and switch off battery optimization for it... Turn off sleep standby...
  9. YellowClaw Honeycomb Oct 11, 2018
    okay will try. Thank you so much.
  10. Prathamesh25 Donut Oct 11, 2018
    beta
  11. malidan Marshmallow Oct 11, 2018
    malidan, Oct 11, 2018 :
    Bad software needs a factory reset it's not like you changing Android version.
    11 month old Note 8
    11 updates
    No factory reset
    No battery drain.
    I don't even have to clear the cache.
  12. malidan Marshmallow Oct 11, 2018
    I remember people reporting issues from day one actually.
    Some people settle and some don't, such is life.;)
    The change logs tell half the story the file size tells the real story, OP Don't fully list bugs fixed or attempted to fix.
  13. chazey2 Ice Cream Sandwich Oct 11, 2018
    chazey2, Oct 11, 2018 :
    Ok mate maybe some don't have all the said issues so yeah maybe settled.
  14. chazey2 Ice Cream Sandwich Oct 11, 2018
    Most complaints are from people Oreo to Pie so it's an Android version. Probably right on bad software needs reset but if it stops the issues then that's what it is.
    Aks41179 likes this.
  15. B_Wrath Lollipop Oct 11, 2018
    Being a beta user, you are expected to search and read for answers first...
    Go read the pinned stable pie announcement thread.. There is a sticky post containing FAQ... Read that..
    Aks41179 and gubro like this.
  16. mrypuri Froyo Oct 11, 2018
    mrypuri, Oct 11, 2018 :
    I earlier said hello neighbor game does not work on OnePlus ,. turns out that is issue with game as it does not work on Android 9 so I am back on beta 4
  17. Iron Stone Eclair Oct 11, 2018
  18. B_Wrath Lollipop Oct 11, 2018
  19. G_shajahan_km_abcd Froyo Oct 11, 2018
    Iron Stone likes this.
  20. malidan Marshmallow Oct 11, 2018
    Every update brings about the same result, so its deffo poor software.
    This is their 6th device model on said software, so there shouldn't the volume of issues there is anymore.
