190
OxygenOS Open Beta 4 for OnePlus 6
  1. hafizua
    Eclair Oct 13, 2018
    hafizua , Oct 13, 2018 :
    everything is great... but volume control sometimes don't work.. after reboot solved the problem for few hours... anyone face the same??
  2. carlosfanini
    Gingerbread Oct 13, 2018
    carlosfanini , Oct 13, 2018 :
    A suggestion for the users having problems on the Beta Build, just factory reset. If you're on Beta Build it means your testing so don't expect for everything to work 100%.
    I've been on the Beta Build since I got this phone and it's been daily driver material. I had issues with battery a few apps but I decided to factory and just restore apps from backup and everything just works now. So again, if you're having issues do a factory reset and test again. If you don't like testing just get back on the Stable builds. Just my two cents.
    ejraney likes this.
  3. Emrah Salo
    Cupcake Oct 13, 2018
    Emrah Salo , Oct 13, 2018 :
    i have the same problem, but with hotspot..
    after the Android update to the latest version when i open Hotspot phone goes restart.. i open n check *#808# wifi area settings n change the wifi area setup than it works 1 day normally.. after one day it makes same crash when i enable hotspot.... i live in Finland and use phone in Turkish language..
    have you got any solution or figure out how to dux this?
  4. thennarasug
    Cupcake Oct 14, 2018
    thennarasug , Oct 14, 2018 :
    Adaptive battery and signal - combo doesn't go well in my OnePlus6.
    anyone else facing this problem? when I turn on adaptive battery and signal app , the signal app closes in background which results in missed chats/calls. I receive the notifications when I open the app.
  5. msthameem
    msthameem , Oct 14, 2018 :
    Yeah I know. Now I am getting used to use profiles :/
  6. thennarasug
    how is that?
    I found a workaround by disabling battery optimization for signal app when adaptive battery mode is on. seems it's working.
  7. msthameem
    NO! I am talking about volumes not adaptive battery. it is working fine for me. Which OS u r using? I am using beta 4. I was using stable pie os and that was having battery issues for me. I was getting only 2 to 3 hours of screen time only. Now I am getting around 5 to 6 hours. May be try that.
  8. S1517289546995
    S1517289546995 , Oct 14, 2018 :
    i am one plus 6 user.
    i am running with open beta pie but true caller is not working.
    plz send solution if someone knows it.
    thanks
  9. ashajethro
    Donut Oct 14, 2018
    ashajethro , Oct 14, 2018 :
    I am using true caller with beta 4, don't know the solution for u coz there's no problem from the beginning for me
  10. pksmith1968
    Gingerbread Oct 14, 2018
    pksmith1968 , Oct 14, 2018 :
    Using the latest beta and having no issues at all using Google Pay. Anyone having problems???
  11. TonioLA
    Ice Cream Sandwich Oct 14, 2018
    TonioLA , Oct 14, 2018 :
    can't use in France. but bank issues related
    pksmith1968 likes this.
  12. Gagan_Shetty_s
    Gagan_Shetty_s , Oct 14, 2018 :
    Hey i am currently in this build, but i wanna move out of beta track and go to official track, so i downloaded the OTA of the official 9.0 and when i try to upgrade it locally i get this error telling that "the version of your selected package is lower than that of the current system. to avoid booting up failure, downgrading is not allowed." does this mean i can never go to the normal OTA track again from beta ? :(
  13. B_Wrath
    Nougat Oct 14, 2018
    B_Wrath , Oct 14, 2018 :
    First tell me... How did you get on the beta build???
  14. Gagan_Shetty_s
  15. Gagan_Shetty_s
    by the way manu said, downloaded ota , local upgrade i did
  16. B_Wrath
    Nougat Oct 14, 2018
    From which beta build??? Did you use OB1??
  17. Gagan_Shetty_s
    yes, from the first open beta for p, right now i am in the latest ob4
  18. B_Wrath
    Nougat Oct 14, 2018
    Did you read the OB1 thread properly??? Completely???
  19. PrakarshX
  20. Gagan_Shetty_s
    umm yeah i did, i was told that complete flashing wud be necessary to go back to the official stable track, and the way to do it was to download the rom and do a local upgrade, i dont mind data wipe, and i followed the instructions , doesnt seem to be working
