223
OxygenOS Open Beta 4 for the OnePlus 7 and OnePlus 7 Pro
  1. Sammy7
    Donut Nov 8, 2019
    OnePlusAim likes this.
  2. Sammy7
    Donut Nov 8, 2019
    Sammy7 , Nov 8, 2019 :
    Should I visit One Plus Care for the same or should I do it by myself.
  3. OnePlusAim
    Honeycomb Nov 8, 2019
    OnePlusAim , via OnePlus 7 Pro , Nov 8, 2019 :
    I'd would Suggest Doing whatever you are Comfortable With XDA has Fastboot zips for Flashing the Roms to Downgrade which is the easiest for me but I don't want you to find yourself in a situation you alone can't fix. I Break my phone all the time while playing with Roms but recovery is simply so I keep playing it may not be the same for you my man
  4. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Nov 8, 2019 :
    Without more info about the battery usage it's hard to say if that is bad. So many different factors. Most often you can find a reason when you dig deep enough in the stats.
    Tjere are alot of optimization that could be missed out on if the charging habits prevents proper optimizations.
    I use BetterBatteryStats myself.
    Some info about battery charging and the adb command that let's you optimize manually. Battery info http://bit.ly/33bqDY2
  5. Garv01
    Cupcake Nov 8, 2019
  6. vmrvenkatesh
    Eclair Nov 9, 2019
  7. Dhanush0610
    Eclair Nov 9, 2019
    Dhanush0610 , via OnePlus 7 Pro , Nov 9, 2019 :
    well I could not do it bro......my device is not at all reading the local upgrade package though it is in the root directory.....can you help ??
  8. OnePlusAim
    Honeycomb Nov 9, 2019
    OnePlusAim , via OnePlus 7 Pro , Nov 9, 2019 :
    I'm Sorry Buddy I'm at work right now I'll give you a full run down when I'm off if someone doesn't beat me to the punch
    M1559313366603 likes this.
  9. OnePlusAim
  10. Dhanush0610
    Eclair Nov 9, 2019
    sure bro.....guide me when you're free....
  11. OnePlusAim
    M1559313366603
    sure bro.....guide me when you're free....​
    what's your tech experience? have you rooted it or Flashed International or T-Mobile Firmware? preparing for later
    Also what is your current Version Beta 4 or 5?
  12. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Nov 9, 2019 :
    Here is the info I usually post
    Update/Downgrade your phone with starting from the community app. Step by step video. Some awesome entertainment during the download included. Downgrade file exists in the first post in OB1.
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-and-oneplus-7-pro.1099154/. Video http://bit.ly/2lPAkuy
  13. OnePlusAim
    ******* Juggalo Coming in Clutch Thanks Buddy XD. I figured you'd get to it before I could XD
  14. OnePlusAim likes this.
  15. Dhanush0610
    Eclair Nov 9, 2019
    I have beta 5 on my phone.....
    and this is the second time I'm trying to revert back .....
    the first time...I could not downgrade....cuz I had a dialogue box popping out saying that the package was of a lower version and it wasn't possible to downgrade....
    now the package is not at all being detected......
  16. Dhanush0610
    Eclair Nov 9, 2019
  17. D1564862970892
    Cupcake Nov 9, 2019
    D1564862970892 , Nov 9, 2019 :
    If it was available there wouldn’t have beta testing out for it again smh.
  18. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Nov 9, 2019 :
    Beta channel exists side by side stable for a very long time. 5/5T just ended beta channel... It's a update channel of its own for beta testers that want to help out testing new functions and builds before they end up in stable. If someone joined beta they need to manually go back to stable channel.
  19. G_Usama_Malik_xoEk
    Cupcake Nov 10, 2019
