223
OxygenOS Open Beta 4 for the OnePlus 7 and OnePlus 7 Pro
  1. Vidvat@3
    Froyo Oct 23, 2019
    Vidvat@3 , via OnePlus 7 Pro , Oct 23, 2019 :
    yah i got it bro thanks a lot!!
    abhilash_saikia likes this.
  2. AbhilashSaikia
    The Lab - OnePlus 8 Pro Reviewer Oct 23, 2019
    AbhilashSaikia , via OnePlus 7 Pro , Oct 23, 2019 :
    Can you share some battery stats?
    Also, for your feedback to be heard you need to let the team know using proper channel.
    Kindly use the feedback channel, let me know if you face any problem with that.
    Thanks.
    Vidvat@3 likes this.
  3. Vidvat@3
    Froyo Oct 23, 2019
    I also have that issue of battry drain
  4. AbhilashSaikia
    Just after installing the update, more than usual battery drain is normal.
    Give some time for the battery to re-calibrate and get optimised further.
    It takes about two-three full charge & discharge cycles.
    But, if after giving the required time, the issue is not solved kindly report.
  5. Vidvat@3
    Froyo Oct 23, 2019
    okayy i will check after that
  6. Russel.lopes
    Froyo Oct 23, 2019
  7. B1558440842285
    Cupcake Oct 23, 2019
    B1558440842285 , Oct 23, 2019 :
    - After updating the Beta 4 , weather updation is not responding properly....
    - software checking screen not in dark mode....which seems to be very ugly.......
  8. c0rsa1r likes this.
  9. E1571648312302
  10. E1571648312302
  11. dr0idman
    Froyo Oct 23, 2019
  12. JNiemi
    Honeycomb Oct 23, 2019
    JNiemi , Oct 23, 2019 :
    Sorry but seems like OnePlus fix one bug and create two new ones. I know it is not easy job to find bugs what are hiding under thousands and thousands lines of code.
    Im trusting that all these bugs will be memories at the latest when OnePlus 9 ProT 7G is published with Android 16 or 17.
    Georgeoneplus7pro and fcarmona like this.
  13. T1542376200684
  14. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 23, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 23, 2019 :
    Tried to understand what could be bad with the front camera now. I don't see it. Maybe in certain type of lightning or something?
  15. dhopmans
    dhopmans , Oct 23, 2019 :
    First yesterday it was CAPSLOCKDAY.
    Second do some research!
  16. a_m28
    Ice Cream Sandwich Oct 23, 2019
    a_m28 , via OnePlus 7 , Oct 23, 2019 :
    what's your phone benchmark result after beta 4??
  17. dhopmans
    Please speak for yourself. Not having any drain myself!
    Pawcio62432 likes this.
  18. Magpie83
    Froyo Oct 23, 2019
  19. Swejuggalo
  20. a_m28
