223
OxygenOS Open Beta 4 for the OnePlus 7 and OnePlus 7 Pro
  1. Leon43
    Donut Oct 23, 2019
    Santi_SAZ likes this.
  2. Santi_SAZ
    Gingerbread Oct 23, 2019
    Leon43 likes this.
  3. KyloWhen
    Honeycomb Oct 23, 2019
    KyloWhen , via OnePlus 7 Pro , Oct 23, 2019 :
    Been having this problem since OB1, bug reports, customer care execs have all not solved my problem.
    My 7 Pro ( and three others) charges at Dash Charge (5v - 4A) levels instead of Warp charge (5v - 6A). Phone reaches ~5.6A for around 30 seconds after plugging in and then immediately drops. Unplugging and try again gives the same result. Different cables, adapters, phones. No change. Even charges
    slowly when switched off( Measured time for charging in detail). Was hoping it'll be fixed after so many betas and so many bug reports, but apparently not.
    OnePlus claimed 48% in 20 minutes during the launch event.
    This is what I have in my multiple charge tests (and across different phones)
    Georgeoneplus7pro likes this.
  4. Dontsh00tmesanta
    Cupcake Oct 23, 2019
  5. baileyhood
    Eclair Oct 23, 2019
    baileyhood , Oct 23, 2019 :
    Is there a link anywhere to download the full Open Beta 4 ROM? And for that matter, is there a place where we can go to get all the latest Betas when they come out? I'm not seeing a link anywhere in the thread to download this. I am coming from stable so I need the full ROM.
  6. KyloWhen
    Try Oxygen Updater on the Play Store.
  7. dex2grigg
    Froyo Oct 23, 2019
    U1567285275692 likes this.
  8. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 23, 2019
    G_ayush_madan_YhBr likes this.
  9. Swejuggalo
  10. V1557905305765
  11. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Oct 23, 2019
    KeepTransisting , Oct 23, 2019 :
    People really need to stop using benchmark programs. They're not good for anything except a pissing match on which numbers are higher.
  12. SkyPlus1
    SkyPlus1 , via OnePlus 7 Pro , Oct 23, 2019 :
    This update is just bad. Nothing is working my phone is like dying. Does anyone has the link to rollback to android 9.0 pie ? Because I don't want to lose my phone because of a bad update. I don't care about my data.
  13. Swejuggalo
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 23, 2019 :
    Haven't done full tests lately but I used to have a full charge at about 80 minutes. Everything in between 60 to slightly over 80 should be normal.
    I usually avoid getting lower than 20% and can usually not drain so much during a day anyway. I slow charge either during the night or Warp charge once during breakfast.
  14. skelz92
    Eclair Oct 23, 2019
    skelz92 , via OnePlus 7 Pro , Oct 23, 2019 :
    did you do a clean install ?
  15. C1566492973084
    C1566492973084 , via OnePlus 7 Pro , Oct 23, 2019 :
    I haven't had any of those issues... but also Beta 3 was working very well for me too
    Y1569837387377 likes this.
  16. SkyPlus1
    What do you mean ? I just received a notification from OnePlus and updated it right away. I regret it.
  17. skelz92
    Eclair Oct 23, 2019
    did you come straight from android 9?
  18. Swejuggalo
    Yeah. Some root and use tweaked kernels just to show a nice number [e]1f609[/e]
    Back at those days I rooted I did it for battery saving and extended possibilities. Nowadays I don't feel the need for it.
    However I can see some use of the benchmark numbers as a measurement on improvement. Some phones mature and improve the results slightly over time.
  19. SkyPlus1
  20. C1566492973084
    there is a roll back package you simply download it and rename the end to .zip and then complete it in local upgrade as normal. yes it will completely wipe your phone.
    R1569160848339 likes this.
