223
OxygenOS Open Beta 4 for the OnePlus 7 and OnePlus 7 Pro
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 23, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 23, 2019 :
    Yeah. Some root and use tweaked kernels just to show a nice number [e]1f609[/e]
    Back at those days I rooted I did it for battery saving and extended possibilities. Nowadays I don't feel the need for it.
    However I can see some use of the benchmark numbers as a measurement on improvement. Some phones mature and improve the results slightly over time.
  2. SkyPlus1
    Cupcake Oct 23, 2019
  3. C1566492973084
    Gingerbread Oct 23, 2019
    C1566492973084 , via OnePlus 7 Pro , Oct 23, 2019 :
    there is a roll back package you simply download it and rename the end to .zip and then complete it in local upgrade as normal. yes it will completely wipe your phone.
    R1569160848339 likes this.
  4. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Oct 23, 2019
    KeepTransisting , Oct 23, 2019 :
    Slightly really doesn't matter when it comes to day to day use though.
    Georgeoneplus7pro likes this.
  5. SkyPlus1
    SkyPlus1 , via OnePlus 7 Pro , Oct 23, 2019 :
    C1566492973084
    there is a roll back package you simply download it and rename the end to .zip and then complete it in local upgrade as normal. yes it will completely wipe your phone.​
    Yeah I know but I just can't find it. I just need the link to download it.
  6. Swejuggalo
    Exactly. Biggest changes seems to happen to vulkan api on most phones. Maybe 1-3 fps improvements overtime in most real useage cases.
    I have never seen a major improvement happening on any phone.
  7. Swejuggalo
  8. Russel.lopes
    Froyo Oct 23, 2019
    Russel.lopes , via OnePlus 7 Pro , Oct 23, 2019 :
    Link given in open beta 1
  9. Matteo.16
  10. C1566492973084
  11. SkyPlus1
  12. SkyPlus1
  13. docnok63
    Jelly Bean Oct 23, 2019
    docnok63 , via OnePlus 7 Pro , Oct 23, 2019 :
    Messenger has its own dark mode in the app. You can use Frost for FB dark mode. Might just wait though. FB 8s testing dark mode for both web and mobile.
  14. SkyPlus1
  15. Borijess3
    Froyo Oct 23, 2019
  16. C1566492973084
    You must be doing something wrong. I was on Beta 3 and decided I wanted to fresh install it completely wiped. So I used the downgrade package to go back to Pie then reinstalled Beta 3 just fine. Now I'm on Beta 4 as of today
  17. SkyPlus1
    I just downloaded it, went to settings, update, click on it and tried to downgrade. It just saying me that it won't let me downgrade it.
  18. C1566492973084
    Does it say "it won't let you downgrade" or does it say "installation failed" ?
    P1570813225656 likes this.
  19. SkyPlus1
    The package version you selected is inferior compared to the actual version of the system. to avoid a failure at the lauching phase, any downgrade is forbidden.
  20. V1rTu
