223
OxygenOS Open Beta 4 for the OnePlus 7 and OnePlus 7 Pro
  1. neha janpandit
    Cupcake Oct 29, 2019
  2. The_Rock90
    Jelly Bean Oct 29, 2019
  3. the_reckoner
    Ice Cream Sandwich Oct 29, 2019
  4. The_Rock90
    the_reckoner likes this.
  5. Joehk
    Joehk , Oct 29, 2019 :
    [QUOTE =“ G_ayush_madan_YhBr,post:20969705,member:1032183”]有人收到常規OnePlus 7的Beta 4嗎?[/ QUOTE]
    一早有了…
  6. wm0304
    wm0304 , via OnePlus 7 , Oct 29, 2019 :
    I found a quite annoying bug:
    I use Google maps quite often for navigation. Since Android 10 the screen, that should stay active all the time while maps is running, keeps deactivating randomly. Sometimes it only stays on for 15 seconds, sometimes it takes several minutes.
    I keep reactivating the screen and after about a dozen or so reactivations the system seems to understand and the screen stays on (at least most times).
    I tried to use the "always on" function/app, but even then the screen turns dark all the time ... :-(
  7. _Salman_Sallu_
  8. _Salman_Sallu_
    H1561035594205 likes this.
  9. martinklaus , via OnePlus 7 Pro Nebula Blue , Oct 29, 2019 :
    Switch to stable an wait for update. What's wrong?
  10. M1565406667675
    Eclair Oct 29, 2019
  11. J1508070026278
    Gingerbread Oct 29, 2019
    J1508070026278 , via OnePlus 7 , Oct 29, 2019 :
    Yup indeed on my OnePlus 7 (6gb/128gb), RAM management is very poor after the 10.0.1 update.. apps are being killed off too aggressively. Tried factory reset and all types of settings tweaks, but the issue still persists.
    E1570731157101 likes this.
  12. sksivakumar1
    Donut Oct 29, 2019
  13. J1508070026278
    I am also in India and got the stable 10.0.1 OTA couple of weeks back
  14. G_Anil_Mallesh_vnna
    G_Anil_Mallesh_vnna , via OnePlus 7 , Oct 29, 2019 :
    Hello Team,
    Since this update I'm unable to use what's app and the gallery feature.
    When I'm trying to send the photos to why's app the system just doesn't respond. Do we have fix to it
    Please Help!
    Thanks
    Anil Mallesh
  15. bkavinoff
    Eclair Oct 29, 2019
    bkavinoff , Oct 29, 2019 :
    Hi, if the problem is using WhatsApp, wouldn't be WhatsApp team work instead of OnePlus work?
    Just saying...
  16. G_Anil_Mallesh_vnna
    No it can't be because other people using different phone are able to use it then why not me, who only has One plus.
    Also I'm facing this issue since I've updated the phone with new versions of it.
  17. Alyafidp
  18. FIROZ77
    Eclair Oct 29, 2019
  19. Liehjan
    Lollipop Oct 29, 2019
    Liehjan , Oct 29, 2019 :
    If you are part of the beta program, you should have got it by now.. You are running ob3 now right?
