223
OxygenOS Open Beta 4 for the OnePlus 7 and OnePlus 7 Pro
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 29, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 29, 2019 :
    If you are on beta. Never.
    You will need to manually revert to stable to get stable. If you can wait for next stable don't update the beta anymore and flash next stable version over the beta. That will wipe the phone but make it go strait to 10.0.2 (assuming it is 10.0.2 that is the next update... normally the logical next version number). If you are in a hurry you can choose from 2 options. Download the downgrade file to 9 from the open beta 1 thread and upgrade to 10.0.1 or flash via adb commands. Both wipes the phone.
    If you like beta just stay and you get beta updates around every 2nd week.
  2. Swejuggalo
    How did you move the file and did you make sure it is a zip?
    Update/Downgrade your phone with starting from the community app. Step by step video. Some awesome entertainment during the download included. Downgrade file exists in the first post in OB1.
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-and-oneplus-7-pro.1099154/
    Video http://bit.ly/2lPAkuy
  3. Nic2112
    Ice Cream Sandwich Oct 29, 2019
    Nic2112 , Oct 29, 2019 :
    It won't come to you if you are running beta. Stable will only be updated on the stable branch so if you are or 10.0.0, you should be getting 10.0.1.
    If you are on Beta-3 or Beta-4, you will never be offered an OTA to go to stable.
    Georgeoneplus7pro likes this.
  4. L1572371079496
    Cupcake Oct 29, 2019
    L1572371079496 , Oct 29, 2019 :
    I am still running on pie,i have the update available via OTA but I didnt do it as it don't know it's beta or stable
  5. Nic2112
    Nic2112 , via OnePlus 7 Pro , Oct 29, 2019 :
    if you are on stable, you won't get beta updates unless you use oxygen updater
  6. L1572371079496
    ok that's means OTA updates via system are stable???
  7. Nic2112
    They are from the stable builds, so OnePlus considers 10.0.1 to be stable, but a lot of users would disagree and say that it still has too many bugs.
    Nonetheless, 10.0.1 is a stable build while the beta branch is on Beta-4 right now.
  8. L1572371079496
    thanks allot. now I feel free to update
  9. Manilo
    Honeycomb Oct 29, 2019
  10. E1570731157101
    Froyo Oct 29, 2019
    E1570731157101 , via OnePlus 7 , Oct 29, 2019 :
    This is true bro, that's why I stopped playing games.
  11. smartbuyer
    Eclair Oct 29, 2019
    J1570370752961 and the_reckoner like this.
  12. Z1572382303106
  13. docnok63
    Jelly Bean Oct 29, 2019
  14. Nic2112
    you have to go back to pie by using an is from my signature, then upgrade from 9.5.3 to 10.0.1
  15. Abhishek R Sharma
    Donut Oct 29, 2019
  16. W1572403464941
    Cupcake Oct 30, 2019
  17. SatyajitRoy1999
  18. Sakshi_Goel55
  19. venkyred20052
    Gingerbread Oct 30, 2019
    venkyred20052 , via OnePlus 7 , Oct 30, 2019 :
    Why OB4 rollout is very slow?
    I used to get earlier open beta updates in a day or two after its release. This time I am still on OB3 and not getting update.
    Can I install OB4 manually on top of OB3? Where do I get install file?
    I am using Oneplus 7 from India
