49
OxygenOS Open Beta 4 for the OnePlus 8 and OnePlus 8 Pro
  1. AlloTomato
    Honeycomb Nov 26, 2020
  2. GeraRubio
    Donut Nov 26, 2020
    GeraRubio , via OnePlus 8 Pro , Nov 26, 2020 :
    I have the same problem
    isamitkz likes this.
  3. khan1992
    Gingerbread Nov 27, 2020
  4. Tee_Eee_Bee
    Ice Cream Sandwich Nov 27, 2020
  5. isamitkz
    Cupcake Nov 27, 2020
    isamitkz , via OnePlus 8 , Nov 27, 2020 :
    You Should register as a beta tester to OnePlus Closed/Open Beta program for nord check on community forums OnePlus Nord Tab.
  6. isamitkz
  7. KobbyLotto
    Eclair Nov 27, 2020
    KobbyLotto , via OnePlus 8 Pro , Nov 27, 2020 :
    Please fix this battery drain, now I'm charging my 0P8 pro 3 times a day. From 100 per cent charge I put in airplane mode every night when I sleep for between 6-7 hours ,I wake up with 79-82 percent battery which is really worrying, before the update that would have been just 92-99 per cent battery when I wake up and that would last me between 8-14 hours a day. Also certain apps makes the phone very warm when using, charging is a bit slower too ,usually took me 1 hour to charge from 0-100 ,now it will take 80 minutes
  8. amine250 , via OnePlus 8 Pro Glacial Green , Nov 27, 2020 :
    You're right, it's a little annoying but I've been ignoring it lately
  9. NavneetSreekumar
  10. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 27, 2020
    Swejuggalo , via OnePlus 8 Pro , Nov 27, 2020 :
    Have you checked on the battery stats? Nothing out of the ordinary? Never charge during the night? Take a screenshot on both apps and full device usage.
    You can force a background optimize via adb.
    Adb installation.
    https://www.xda-developers.com/install-adb-windows-macos-linux/
    Background optimizing (adb shell) : cmd package bg-dexopt-job
  11. LovelyHeart
  12. Swejuggalo
    You mean going to stable? Download the latest version if that version is newer than the currently installed beta. That will allow a manual upgrade from local upgrade. It will wipe the phone though.
    Currently you can install 11.0.2.2 over beta 4
  13. LovelyHeart
    LovelyHeart , via OnePlus 8 Pro , Nov 27, 2020 :
    What would you recommend?
  14. swolfman
    Eclair Nov 27, 2020
    swolfman , Nov 27, 2020 :
    I am on open beta 4 and tried to install 11.0.1.1 - did not allow me ... as you mentioned
    Where can i download the FULL OTA version 11.0.2.2 ? ( Europe )
    Thanks
  15. Swejuggalo
    No official source this early. But various sites has got links to O eplus servers.
    For example here.
    https://www.rprna.com/updates/oxyge...-2020-security-patch-and-more-download-links/
    Or use the app Oxygen Updater.
    Their own homepage usually update after the staged rollout have finished.
  16. Swejuggalo
    Staying on beta or using stable? It's a matter of taste and personal interest really. I join beta as soon as possible and never leave it as long as I own the phone.
    See my post above for files.
    LovelyHeart likes this.
  17. Harish0599
  18. Swejuggalo
  19. swolfman
    Eclair Nov 27, 2020
    For those of you with the same issue ... i managed to move from OB4 to 11.0.2.2 taking a "long path"
    First downgrade to Andorid 10 .... upgrade to 11.0.1.1 and manualy installed the incremental OTA to 11.0.2.2 which is available in forums
    G1596645199075 likes this.
  20. RajaKumar203
    RajaKumar203 , via OnePlus 8 , Nov 27, 2020 :
    Nhi realme x2 me toh aisa kuch nhi hota
