49
OxygenOS Open Beta 4 for the OnePlus 8 and OnePlus 8 Pro
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 21, 2020
  2. Swejuggalo
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Nov 21, 2020 :
    Enable showing the gesture navigation bar.
    O1590163044426 likes this.
  3. HrudayH111
    Donut Nov 21, 2020
    HrudayH111 , via OnePlus 8 , Nov 21, 2020 :
    Whats wrong with you oneplus???? Stable builds are buggy and stuttery (11.0.1.1) for Oneplus 8, where as right from open beta 3 to now opene beta 4 is legitimately smooth as f, its just perfectly polished software experience i have experienced since i bought the phone!!! and this is desperately being expected from a OnePlus device. its truly that mediocre until open beta 4 for the op8.
    PhoenixEmperor likes this.
  4. SuperGreenie
    Cupcake Nov 21, 2020
  5. ASHWIN SHETTY33
    ASHWIN SHETTY33 , via OnePlus 8 Pro , Nov 21, 2020 :
    Y u guys try to mess thing up, in evry update for god sake,
    U ur one OB UPDATED, PHONE CALL WILL ACT LIKE MAD,IN SCREEN SUDDEN VISSION COMFORTABLE MODE WILL BE ACTIVATED OUT OF NO WHERE, IF U MESS THINGS UP,GO DO IT IN YOUR HOME,NOT IN UR UPDATE, GOD WHY I CHOOSED THS MOBILE COMPANY
    S1592114499326 likes this.
  6. alessan
    Honeycomb Nov 21, 2020
  7. Josh261995
    Froyo Nov 21, 2020
  8. Swejuggalo
    So you are saying beta 3 and 4 has been smooth for you and stable not?
    When you were on stable was that a clean install or upgraded from 10? Is the betas also upgraded from 10 or are they clean setup?
    Sometimes betas can be better. Sometimes they are worse. Sometimes a clean install and a upgraded device can be a huge differance too.
  9. Swejuggalo
    Betas can be a mess to... It's beta after all.
    Be aware if regretting it it will wipe the phone.
    I always use beta and never leave it as long as I use the phone. But that is because I like to beta test. I endure possible issues. I try a lot of trial and error when needed. Even factory reset if needed of various reasons. And I do my best to replicate issues and report them as often as possible.
    lkysmruti and Llaa like this.
  10. Mr.pransh
  11. lkysmruti , via OnePlus 8 Pro Ultramarine Blue , Nov 21, 2020 :
    Same for me. I have shifted to Oneplus 8 Pro from Mi flagships. I was always in beta testing for miui roms.
    So using OBs for Oos also.
    But the thing which annoys me in this phone is the GREEN and RED Tint, and its more visible in OB4 update.
    What about you?
    Can you tell your display experience??
  12. ecansar
  13. Swejuggalo
    Think the screen problem is bigger too, in some situations at least. But for most use I still don't see much of a problem.
    lkysmruti likes this.
  14. Swejuggalo
  15. Swejuggalo
  16. S1592114499326 likes this.
  17. ecansar
    ecansar , via OnePlus 8 , Nov 21, 2020 :
    On beta 3 has been downloaded, it does not work. 5G
  18. Swejuggalo
  19. ecansar
