114
OxygenOS Open Beta 5 for OnePlus 6
  1. B_Wrath
    Junior Moderator Junior Moderator Oct 26, 2018
    B_Wrath , Oct 26, 2018 :
    What error does this two apps show ???
  2. Harry Sanjay
    Cupcake Oct 26, 2018
    Harry Sanjay , Oct 26, 2018 :
    first in phone call app : in switch call is not properly working and in some time when you answering a normal call itself it's showing an error and second problem is in conference when you connecting conference call and then if you cut the second call in the line means the name in the screen is not changing to first caller name it's showing conference call itself but the second call even cut !! can you resolve this problem ?
  3. B_Wrath
    You are not explaining properly... How can one help you when you cannot explain your issue... What is the exact error???
    And the conference call seems to be a bug... Give a feedback here...
  4. kwaasung
    Froyo Oct 26, 2018
    kwaasung , Oct 26, 2018 :
    what happened to beta 4? are we gonna get that touch latency update? as stable version.
    edit:if you don't know,or don't want to reply please ignore this post. thank you.
  5. bhagwat98
    Donut Oct 26, 2018
    bhagwat98 , Oct 26, 2018 :
    when always on display back?
    I m ready to compromise with my battery.i think lift to on and always on display both options are provide.
  6. adrianchettiar
    Froyo Oct 26, 2018
    adrianchettiar , Oct 26, 2018 :
    are you running the Open Beta 5 currently?
  7. carlosfanini
    Gingerbread Oct 26, 2018
    Adrian Chettiar likes this.
  8. PrakarshX
    Ice Cream Sandwich Oct 26, 2018
    PrakarshX , Oct 26, 2018 :
    how to make gpay work with magisk
  9. phemt
    phemt , Oct 26, 2018 :
    Is someone facing fingerprint issues? The sensor sometimes doesn't work.
  10. Divyanshu_Sankhwar
    Divyanshu_Sankhwar , Oct 26, 2018 :
    Remove your fingerprint and add it again, probably try adding same finger twice.
    It used to not work for me, I added it twice and now works flawlessly.
  11. Rohitpande2009
    Eclair Oct 26, 2018
    Rohitpande2009 , Oct 26, 2018 :
    there is dispaly bug in Open Beta 5.
    display is switching from night mode to day mode abruptly & its flickring...during day or when went from less bright to great Bright areas...
    prokiller1199 likes this.
  12. Divyanshu_Sankhwar
    Rohitpande2009 likes this.
  13. Rohitpande2009
    Eclair Oct 26, 2018
    yah may be its automatic brightness problem.
  14. Phanichitturi
    Phanichitturi , Oct 26, 2018 :
    HI ONEPLUS TEAM,
    I am facing heating issues with my oneplus 6 mobile . Can u help me by solving this problem for me.
  15. Divyanshu_Sankhwar
    Send logs to oneplus team, they are not present here.
  16. Phanichitturi
    how can I check logs
  17. Divyanshu_Sankhwar
    Here is the process:
    1. Go Setting>Battery>Battery optimization>right upper corner 3 dots>Advanced optimization, enable "Sleep standby optimization"
    2. Go to phone dialer app and dial *#800#
    3. Select the first option which says “oneplus Logkit”, delete history log, click “move log path to built-in SD card”
    4. Click "advanced", choose "save log type", select all these options (Kernel, Main, System, Radio, Event, Tcpdump), then click OK
    5. Click “save log”, when it informs you whether to reboot, please lick “cancel”
    6. When battery drains heavily under normal usage, go to settings-battery, and take a screenshot of the battery consuming situation
    7. Then enter oneplus Logkit, choose “other log info”, click “get top info”, “battery history” every several minutes and “get bugreport info” once
    8. After you get it, enter “oneplus Logkit”, choose “save log” and “move log path to built-in SD card” again to stop them.
    Finally, enter files>internal storage>oem_log, find the folder, long press and click right upper corner three dots to compress it. You can transfer the logs to Google drive and share us a link with specific description
  18. Phanichitturi
  19. Divyanshu_Sankhwar
  20. Divyanshu_Sankhwar
