114
OxygenOS Open Beta 5 for OnePlus 6
  1. vriesdejoop Ice Cream Sandwich Oct 28, 2018
    vriesdejoop, Oct 28, 2018 :
    I can see them..... you are not the first with this complaint, not seen any solutions till now. the advice is to do a full reset......
  2. rahuldw181 Ice Cream Sandwich Oct 28, 2018
    rahuldw181, Oct 28, 2018 :
    i did it twice. no change.
  3. vriesdejoop Ice Cream Sandwich Oct 28, 2018
    like I said, have not seen a solution. sent it as a bug report
    phemt likes this.
  4. H1532099108401 Eclair Oct 28, 2018
    H1532099108401, Oct 28, 2018 :
    Bugs, and inconsistencies that I've noticed.
    -In recents it shows the ability to go full screen or default even when notch is disabled... so the option is kinda pointless when notch is disabled.
    -In recents you can press the menu button of the app on the left, which seems odd and pointless.
    -It lags when scrolling through recents very fast with the back,home navigation bar pill.
    -In landcape with the back home navigation bar pill, trying to scroll through the recents with the pill does nothing but the pill changes to the line that appears when scrolling through recents in portrait.
    -In landscape The alert slider pop up would appear on the rightside of the display for a second and then teleport to where the alert slider is.
    -Swiping up on the Back,home navigation bar pill while in an app gives no haptic feedback, which feels incomplete.
    Not a bug but... sort of a wish
    -The dark mode in Google's "stock" Android makes the quick toggle panel black instead of grey and I really like that instead of Grey, also it makes more sense since we have Amoled.
    -Since in pie the recents are dictated by the launcher, it would be really nice to have the ability to switch between horizontal and vertical recents. I prefer the horizontal aesthetic but vertical recents are quicker to access and go through.
  5. phemt Ice Cream Sandwich Oct 28, 2018
    phemt, Oct 28, 2018 :
    Mmmm so it's useless going for a factory reset. Good to know . I have this problem too.
    rahuldw181 likes this.
  6. A.N.Hemanth Eclair Oct 29, 2018
  7. Deactivated User Oct 29, 2018
  8. M1538054580889 Cupcake Oct 29, 2018
    M1538054580889, Oct 29, 2018 :
    I could not upgrade to oxygen open beta 5...my one is 9.0.1..how I can use open beta 5?plzzz hlp me
  9. B_Wrath Lollipop Oct 29, 2018
    B_Wrath, Oct 29, 2018 :
    If you can't follow the simple instructions mentioned in the opening thread, then open beta isn't for you...
    Kytharsis, zoran81 and Vinay_NS like this.
  10. Rrspikes Froyo Oct 29, 2018
    Rrspikes, Oct 29, 2018 :
    It shows in the notification drop-down shade.
    I had to update several apps before I was able to get a screenshot of the download progress.
  11. G_Karothikeyan Honeycomb Oct 29, 2018
  12. G_Karothikeyan Honeycomb Oct 29, 2018
    G_Karothikeyan, Oct 29, 2018 :
    Install open beta rom
  13. A.N.Hemanth Eclair Oct 29, 2018
    A.N.Hemanth, Oct 29, 2018 :
    no not rolled out. I didn't receive it
  14. M1538054580889 Cupcake Oct 29, 2018
  15. B_Wrath Lollipop Oct 29, 2018
    What do you mean???
  16. B_Wrath Lollipop Oct 29, 2018
    Beta 5 was rolled out long back... It will be available only for Beta users... Not stable users...
    Kytharsis and A.N.Hemanth like this.
  17. M1538054580889 Cupcake Oct 29, 2018
  18. B_Wrath Lollipop Oct 29, 2018
    Did you follow the exact procedure mentioned in the opening post of this thread ??
  19. M1538054580889 Cupcake Oct 29, 2018
  20. B_Wrath Lollipop Oct 29, 2018
    What did you do after that ??
