162
OxygenOS Open Beta 5 for the OnePlus 6 and OnePlus 6T
  1. Tee_Eee_Bee
    Ice Cream Sandwich Apr 7, 2020
    Tee_Eee_Bee , via OnePlus 6T , Apr 7, 2020 :
    That's an Android 10 design. There is a way to remove, I think you need to be rooted.
    Search through the thread for it.
    JAGADISH BHATTA and Caoimhín like this.
  2. rhyd1am
    KitKat Apr 7, 2020
    rhyd1am , via OnePlus 6T , Apr 7, 2020 :
    The space is entirely intentional to aid with gesture navigation. It's exactly the same on my pixel 2xl as it is on my OP6t.
    You can reduce the size of it by using adb. I forget now what the exact command is, but I'm sure if you search you can find it.
    Pepa1977 and Caoimhín like this.
  3. B_Wrath
    Nougat Apr 7, 2020
    B_Wrath , Apr 7, 2020 :
    You installed the beta without knowing how to rollback?
    Read this thread completely and you'll know how to rollback.
    And like any beta tester, search and read before posting.
    M1586157211412 and Caoimhín like this.
  4. Tee_Eee_Bee
    If you're still on Open Beta 5, then you can download stable 10.3.2 from your local OnePlus support page and install via local upgrade.
    You shouldn't lose any data as 10.3.2 has a newer build date, but it's still a good idea to do a backup.
  5. D.Sai Suhail Baba
    Jelly Bean Apr 7, 2020
    D.Sai Suhail Baba , Apr 7, 2020 :
    cmd----adb devices
    adb shell wm overscan 0,0,0,-75
    Default value:- adb shell wm overscan 0,0,0,0
    Full Screen:-adb shell wm overscan 0,0,0,-100
    Pepa1977 likes this.
  6. B_Wrath
    Nougat Apr 7, 2020
    Ya. That will be breaking the entire UI. Half the thing misbehave when you do it.
  7. D.Sai Suhail Baba
    yes
  8. D.Sai Suhail Baba
  9. D.Sai Suhail Baba
    It will be better to complain about this issue in forum
  10. rhyd1am
    KitKat Apr 7, 2020
    If you're running OB5, then you can simply download 10.3.2 (stable) from your local OnePlus support page, and install it via local upgrade.
    However, if you have already updated to OB6 then you have to either wait for the next stable to be released and install that via local upgrade (assuming it has a more recent build date than OB6). Or you'll have to use the rollback package for your device, and then upgrade from there to the latest stable build.
    Caoimhín and M1586157211412 like this.
  11. B_Wrath
    Nougat Apr 7, 2020
    There is no need to complain here in forum. Google changed it. It's upto them to fix it.
    Caoimhín likes this.
  12. D.Sai Suhail Baba
    yup
  13. M1586157211412
    Cupcake Apr 7, 2020
    M1586157211412 , via OnePlus 6T , Apr 7, 2020 :
    Yeah. That's sounds like a good idea. I'll try it and get back to you. Thanks all the same.
    rhyd1am likes this.
  14. M1586157211412
    Cupcake Apr 7, 2020
    Lol. I've tried it and it worked. My Oneplus 6t is now on 10.3.2..Thanks for your help once more.
  15. tejasacharya
    Cupcake Apr 7, 2020
    tejasacharya , via OnePlus 6T , Apr 7, 2020 :
    Open Beta 6 is just released.
    I'm on stable 10.3.2;
    should I go for incremental beta update or full beta update ?
    updated successful with OB6 !
    So far everything is running smooth.
    looking forward to check Dual channel network acceleration.
  16. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 7, 2020
    Caomhin , via OnePlus 6T , Apr 7, 2020 :
    tejasacharya
    should I go for incremental beta update or full beta update ?​
    Full as its a Beta Build.
    Read the first post by Manuj first, you will no longer receive Stable OTA updates if you install Beta
    tejasacharya likes this.
  17. tejasacharya
    Cupcake Apr 7, 2020
  18. bojantomic
    Honeycomb Apr 7, 2020
    bojantomic , via OnePlus 6T , Apr 7, 2020 :
    For the millionth time, that space is not a bug nor can or should it be removed. It makes typing actually comfortable, as the keyboard would be too low otherwise. It's a standard thing for Pixels, for example, as well as iPhones etc.
    AanandRoy, Caoimhín and Artemus like this.
  19. Durgesh_06
    Eclair Apr 7, 2020
    Durgesh_06 , via OnePlus 6 , Apr 7, 2020 :
    after updating 10.3.2 official update i have facing so many problems like ... battery is draining to fast , face lock not working properly after 3 unsuccessful attempt any body can open it, most of the app is not working properly .
    EL1TxE likes this.
  20. B_Wrath
    Nougat Apr 7, 2020
    Then all in the stable update thread!
    Artemus and Caoimhín like this.
