162
OxygenOS Open Beta 5 for the OnePlus 6 and OnePlus 6T
  1. Tee_Eee_Bee
    Jelly Bean Feb 28, 2020
    Tee_Eee_Bee , via OnePlus 6T , Feb 28, 2020 :
    You can select the vibration intensity and pattern for phone calls and sms under Settings -> Sound & Vibration
  2. BlimBlom
    Cupcake Feb 28, 2020
  3. G1581914197751
    G1581914197751 , Feb 28, 2020 :
    Sorry I ask a one questions I can update Beta 5 from Android 9 Beta17
    or Android 9 Beta17 > 10.3.1 > Beta 5 ?
    Thank you advise
  4. Tee_Eee_Bee
    A9 -> 10.3.1 -> OB5
  5. alryder
    Gingerbread Feb 28, 2020
    alryder , Feb 28, 2020 :
    Scheduled Do Not Disturb doesn't seem to be working in Open Beta 5. I have checked my settings and it should turn on automatically at 10:00 PM but it has not the last two night. I have submitted a bug report.
  6. Minttaipeng
    Donut Feb 28, 2020
  7. Caomhin
    9 Series Expert, Participator of the Year Community Expert Feb 28, 2020
    Caomhin , via OnePlus 6T , Feb 28, 2020 :
    You can try, but if it fails, you might need to be on Android Stable, 9.0.17 then update to 10.3.1, then to Beta 5.
  8. Tony Khatri
    Froyo Feb 28, 2020
  9. sahilliaqat96
  10. Artemus
    Moderator, Community Hero 2020 Moderator Feb 28, 2020
    Artemus , Feb 28, 2020 :
    Yes... Oxygen Updater gets the same update as an OTA.
    drl431 and Caoimhín like this.
  11. sahilliaqat96
  12. sameerays
    Eclair Feb 28, 2020
    G_Dhanapal_mEPD likes this.
  13. Caomhin
    As per @Sufwan, Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    This will not delete your apps data but you will have to provide permissions again.
    Also just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
  14. G1581914197751
    Thank you for help , Right now I update OP6T A9 Beta17 > A10 Beta1 > Beta5
    Caoimhín likes this.
  15. G_Nader_Kabir_vfEP
    G_Nader_Kabir_vfEP , via OnePlus 6 , Feb 28, 2020 :
    why just updated and fixed only for ,,,,, India,,,,India,,,,,, India,,,, India [e]1f631[/e]🤯[e]1f612[/e]🤔🤔[e]1f612[/e][e]1f612[/e][e]1f631[/e]​
  16. G_Nader_Kabir_vfEP
    why just India,,,India,,,,India,,,,India,,,???🤔🤨[e]1f612[/e]🤯[e]1f631[/e]
  17. G_Nader_Kabir_vfEP
    G1581914197751
    Thank you for help , Right now I update OP6T A9 Beta17 > A10 Beta1 > Beta5​
    why just India,,,India,,,,India,,,,India,,, update???🤔🤨[e]1f612[/e]🤯[e]1f631[/e]
  18. gr8ak
    Donut Feb 28, 2020
  19. G1581914197751
    I found some bugs when we charging battery every time around 2-3 min have a sound (same the first time connect to fast charging. )
    sameerays1997 likes this.
  20. missing_s
