162
OxygenOS Open Beta 5 for the OnePlus 6 and OnePlus 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 3, 2020
    Caomhin , via OnePlus 6T , Mar 3, 2020 :
    You could try, it will only update if it is a newer build than the current version of OOS you currently have on the phone.
    But make a backup before doing so, just in case.
    If you can't find a copy of 9.0.9, you can get it from here for OP6 .
    https://oneplusupdates.com/device/oneplus-6
  2. Master_TC
    KitKat Mar 3, 2020
    Master_TC , Mar 3, 2020 :
    It works without problems. I and many other have done it.
    Do you get a error message or something else?
  3. VikramMohal
    Jelly Bean Mar 3, 2020
    VikramMohal , Mar 3, 2020 :
    Master_TC
    Do you get a error message or something else?​
    yes. corrupt file, error
  4. Master_TC
    KitKat Mar 3, 2020
    Ah OK, i and some others had this error message too at the beginning.
    Download the full ROM from the OP support page. This works.
    Don't use the Oxygen Updater.
  5. VikramMohal
    actually I already downloaded from Official website. it's take huge data
  6. Master_TC
    KitKat Mar 3, 2020
    Corrupt file means, that something went wrong during the download.
    There is nothing todo, download again.
    The update from 10.3.1 to beta 5 works definitly without problems.
    After download check the MD5!
    mohal likes this.
  7. Mashallah786
    Eclair Mar 3, 2020
  8. Mashallah786
    Eclair Mar 3, 2020
    Mashallah786 , Mar 3, 2020 :
    Am on 9.0.09 now, which rom should i flash to go on A10
  9. VikramMohal
    ok I will
  10. Master_TC
    KitKat Mar 3, 2020
    Open Beta or Stable?
  11. Mashallah786
    Eclair Mar 3, 2020
  12. Master_TC
    KitKat Mar 3, 2020
    OK, then you are wrong here, because it's the Open Beta thread.
    I would download the full 10.3.2 ROM and install it over the lokal upgrade.
    After that make a factory reset in recovery mode. You will loose all your data!!!
    The battery needs 3-5 days to settle down. At the beginning you have huge battery drain, but it gets with the days better and better.
  13. Pooja
    Cupcake Mar 3, 2020
    Pooja , Mar 3, 2020 :
    pls inform one plus 5t last update which day launch
    last update is very bed
    my phon is hang
  14. B_Wrath
    Junior Moderator Junior Moderator Mar 3, 2020
    B_Wrath , Mar 3, 2020 :
    This is not the 5T thread. Go discuss in relevant threads.
    Artemus likes this.
  15. PeppePug
    Eclair Mar 3, 2020
  16. Master_TC
    KitKat Mar 3, 2020
    You can download it from the official support page.
    PeppePug likes this.
  17. Caomhin
    If you want Stable, download 10.3.2. If you want Beta, then the Beta 5 rom is available from the link below.
    For 10.3.2 you will need to get the full ROM from 3rd party app Oxygen Updater from the Playstore, as I have not found direct links to the latest version full rom zip yet.
    Click the Beta Build tab
    https://www.oneplus.com/ie/support/softwareupgrade/details?code=PM1574156173727
    Artemus likes this.
  18. saifrohan
    Cupcake Mar 3, 2020
  19. svankius
    Cupcake Mar 3, 2020
    svankius , via OnePlus 6T , Mar 3, 2020 :
    My issue is, when I walk with Endomondo, GPS some time is OK, but sometimes it disappears. After turning screen ON, it again apears, and for some time again it is OK. Yesterday, I walked as always almost 5km, but Endomondo said only 4km. So GPS is big problem in this beta update [e]1f62d[/e]
  20. Amit_Dhar
    Donut Mar 3, 2020
