81
OxygenOS Open Beta 5 for the OnePlus 7 and OnePlus 7 Pro
  1. jaylenr
    Cupcake Nov 12, 2019
    jaylenr , Nov 12, 2019 :
    then why haven't I gotten my oxygen 10.0.1 update and the other one plus devices have
  2. dhopmans
    Honeycomb Nov 12, 2019
    dhopmans , Nov 12, 2019 :
    No i'm on Bèta and for now it's choosing between 2 not so stable builds.
    Having a OnePlus since OnePlus One so i known where i'm talking about.....
  3. A1566660222123
    A1566660222123 , Nov 12, 2019 :
    camera update required. Facing heating problem while paying game aftef the new update of android 10. Well its been moths now people demanding a major cera update and you are ignoring it then and now. please its a humble reqysst.
  4. ronnyhawks
    Ice Cream Sandwich Nov 12, 2019
    ronnyhawks , Nov 12, 2019 :
  5. Garikipati tej
  6. Gerardo190495
    Eclair Nov 12, 2019
    Gerardo190495 , via OnePlus 7 Pro , Nov 12, 2019 :
    Power off your device. You can do that by pressing power button and selecting “Power off”.
    Once device is completely shut down, press and hold Volume down and power key simultaneously until you see OnePlus and Android logo.
    Release the keys.
    Now select your preferred language.
    Tap on “Wipe Data and cache”.
    Then select “Wipe cache”.
    Give your consent to wipe cache by tapping on “Yes”.
    Now reboot your device.
    All the cache data will be cleared now.
    docnok63 likes this.
  7. mohit_011111 , via OnePlus 7 Mirror Gray , Nov 12, 2019 :
    wipe clean the datat once
  8. mohit_011111 , via OnePlus 7 Mirror Gray , Nov 12, 2019 :
    just wipe clean the data once.
    For other bugs like auto closing of apps try intelligent control under battery optimisation.
    I think the issue is with jio app as i have seen the same problem with redmi k20 pro and fingerprint issue can be resolved by registering same fingerprint twice.it works way faster.
  9. JmcRepair33
    JmcRepair33 , Nov 12, 2019 :
    No you use the recovery of the phone. ion the recovery click wipe data cache and then click on Wipe CACHE. if you click that options it wont wipe your data just cache
  10. mohit_011111 , via OnePlus 7 Mirror Gray , Nov 12, 2019 :
    faced faster battery drain issue when i was on OB3.after oB4 things got worse.After getting OB5 i did a complete wipe now it is normal.
  11. JmcRepair33
    thats correct, many people are reporting that issue, So that would be your best bet if you havethe time to redo everything if not wipe the cache and should work fine and wait to B 6 comes out. When in Doubt always do a clean flash Anyhow
  12. mohit_011111 , via OnePlus 7 Mirror Gray , Nov 12, 2019 :
    Yes after that wipe things are working fine.
  13. atharvanaikk
    Eclair Nov 12, 2019
    atharvanaikk , Nov 12, 2019 :
    Anyone else having extremely low screen on time on beta 5? The overall battery life seems to have been affected since Android 10
  14. JmcRepair33
  15. atharvanaikk
    Eclair Nov 12, 2019
  16. L1573484126996
    L1573484126996 , Nov 12, 2019 :
    youtube live streams are freezing and dark screen with only live stream sound. please feedback someone
  17. JmcRepair33
    Force Stop and clear data on youtube app
    if not reinstall it, if thats doesnt work full wipe on phone because no one else having that issue. Do you have good internet speed right now?
