64
OxygenOS Open Beta 5 for the OnePlus 8 and OnePlus 8 Pro
  1. ritesh808
    Honeycomb Dec 23, 2020
    ritesh808 , via OnePlus 8 Pro , Dec 23, 2020 :
    Nope. Tried that, still no problem.
    While this is mostly true, they do fix many issues. It just depends on the priority of the issue.
    #81
  2. Steuuplait
    Froyo Dec 23, 2020
    Steuuplait , Dec 23, 2020 :
    [QUOTE = "dadoudidouda, message: 22551442, membre: 1528643"] a dit:
    Merci pour le lien, je vais essayer quand j'aurai le temps, mais personne ne devrait avoir à passer par là pour obtenir une fonctionnalité annoncée par OnePlus [/ QUOTE]
    Bonjour
    J'ai suivi ce tuto et cela n'a pas fonctionné sur mon OP8.
    Bonne journée
    #82
  3. emonisoneplus
    Cupcake Dec 23, 2020
    emonisoneplus , via OnePlus 8 , Dec 23, 2020 :
    I m on stable version i have L1 support on my oneplus 8.
    #83
  4. Swejuggalo
    OnePlus 9 Series Expert Community Expert Dec 23, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Dec 23, 2020 :
    You may need to report this via the feedback tool with the steps on how to replicate. When doing so they get a little log. They might return and ask for a bigger log asking you to replicate the issue while logging it.
    #84
    RahulSinghania99 and ritesh808 like this.
  5. noka6e3umenu
    Froyo Dec 23, 2020
    #85
  6. Łukasz Wielgus
    Łukasz Wielgus , via OnePlus 8 Pro , Dec 23, 2020 :
    I have a problem after the new alarm clock update. it cannot be turned on, you have to click 100 times and it works once and so every time I have to create a new alarm clock
    #86
  7. Hisam139
    Froyo Dec 23, 2020
    Hisam139 , via OnePlus 8 Pro , Dec 23, 2020 :
    Brother Force 120hz on every app and enjoy.
    #87
  8. Anal nambiar
    Eclair Dec 23, 2020
    #88
  9. ErynOP
    Gingerbread Dec 23, 2020
    #89
    abhikothari111 likes this.
  10. RK8531
    Froyo Dec 23, 2020
    #90
    S1590323727081 likes this.
  11. RK8531
    Froyo Dec 23, 2020
    #91
  12. emerowo
    Froyo Dec 23, 2020
    emerowo , Dec 23, 2020 :
    doesn't work clock alarms - I can't turn on, and change the alarm hours !!!!!
    This is very important - please correct it quickly !!!!
    #92
  13. kp17
    Donut Dec 23, 2020
    kp17 , via OnePlus 8 , Dec 23, 2020 :
    I want to update to stable version but it's not allowing me to update to stable version how can I move from beta to stable?
    #93
  14. RK8531
    Froyo Dec 23, 2020
    RK8531 , via OnePlus 8 Pro , Dec 23, 2020 :
    Wait for December security patch of the stable version that maybe released this week.
    #94
  15. cmpllnt , via OnePlus 8 Pro Glacial Green , Dec 23, 2020 :
    Still no fix for the Widevine issue.
    I bought an 900 Euro Smartphone an OnePlus ist unable to fix this issue for a couple of month. Are you kidding us?
    Every 200 Euro Xiaomi is able to play L1 content.
    #95
    D1536478086237 and rohitrana like this.
  16. kanouted10s
    #96
  17. Hisam139
    Froyo Dec 23, 2020
    #97
  18. kanouted10s
    #98
  19. Hisam139
    Froyo Dec 23, 2020
    1. Use Autohz app from play store.
    2. Use adb command to force 120hz:
    adb shell settings put global oneplus_ screen_refresh_rate 0
    #99
  20. kanouted10s
    kanouted10s , via OnePlus 8 Pro , Dec 23, 2020 :
    thanks!
