270
OxygenOS Open Beta 6 for OnePlus 6
  1. M1537520190017 Donut Nov 8, 2018
  2. fernsruben Gingerbread Nov 8, 2018
    fernsruben, Nov 8, 2018 :
    You're running the latest stable release.
    And, don't bother running the beta. You're better off with the stable :)
    zoran81 likes this.
  3. E1508091245035 Cupcake Nov 8, 2018
  4. fernsruben Gingerbread Nov 8, 2018
    Scroll up, someone has already provided instructions and links.
  5. E1508091245035 Cupcake Nov 8, 2018
    E1508091245035, Nov 8, 2018 :
    it is showing page not found can please share package link
  6. titokill Donut Nov 8, 2018
  7. E1508091245035 Cupcake Nov 8, 2018
    done what mentioned in the roll back process but it is not helpful.
  8. M1537520190017 Donut Nov 8, 2018
    M1537520190017, Nov 8, 2018 :
    if i want to run beta so what is the process??? is any official update came to my phone for beta or i have to download via link?
  9. fernsruben Gingerbread Nov 8, 2018
    Search the thread/ forums please :)
    Everything has been explained many times.
    zoran81 likes this.
  10. Syed Ameen Ahmed Jafri Donut Nov 8, 2018
    Syed Ameen Ahmed Jafri, Nov 8, 2018 :
    it's already applied when it sees human faces
  11. M1537520190017 Donut Nov 8, 2018
    bro is my device run both stable and beta ?.Means as i screenshot that my device is in 9.0.2 which is stable version but is it necessary to update open beta 5 to open beta 6? if i update to open beta 6 then i should downgrade my stable version 9.0.2 to 9.0? Or i can run both 9.0.2 with open beta 6?
  12. fernsruben Gingerbread Nov 8, 2018
    listen, there are currently two update channels:
    1. Stable: A stable software release is so named because it is unchanging. Its behaviour, functionality, specification or API is considered 'final' for that version.
    2. Beta: A pre-release of software that is given out to a large group of users to try under real conditions. Beta versions have gone through alpha testing inhouse and are generally fairly close in look, feel and function to the final product; however, design changes often occur as a result.
    If you are on beta, and wish to remain on beta, you would not need to shift to stable and then re-shift to beta, again, obviously.
    So if you are on OB5, you should have already got the OTA to OB6, if not, wait!
    Also, if a user, who decidedly runs beta on their device, is doing so, should be expected to know these differences. If not, shoo back to stable.
    P.s., please search the threads.
    And no! Do not reply with -
    1. "Bro, do not reply if you cannot help".
    2. "Hey you! If you can not help, keep your f*****g mouth off fooooaaarum!".
    3. "What is this attitude maaahn? Kant halp honly? *insert hindi swearing*!"
    Just, dont.
  13. YellowClaw Honeycomb Nov 8, 2018
  14. veeraj97 Cupcake Nov 8, 2018
  15. M1537520190017 Donut Nov 8, 2018
    how many of u suffer from the play storw download notification is disaapear problem in 9.0.2 version??
  16. gvamsi_krish Eclair Nov 8, 2018
  17. gvamsi_krish Eclair Nov 8, 2018
    gvamsi_krish, Nov 8, 2018 :
    This is the thread for Beta version. Please post your query in respective thread.
    BTW you can change notification setting for playstore to get download notification.
  18. gvamsi_krish Eclair Nov 8, 2018
    I'm using my phone with latest OP6_Beta_06. After this update, unable to save a contact with name - getting saved only with number. Is anyone facing similar problem?
  19. E1508091245035 Cupcake Nov 8, 2018
  20. gvamsi_krish Eclair Nov 8, 2018
    currently you are on which version?
    and at what stage you are getting the mentioned error?
