270
OxygenOS Open Beta 6 for OnePlus 6
  1. E1508091245035 Cupcake Nov 8, 2018
    E1508091245035, Nov 8, 2018 :
    currently iam one oneplus 6 open beta 06 version & when iam manually installing from setting system manual update after selecting stable version from manually upgrade it is showing error can not downgrade. please assist further.
  2. ShivamRathi Cupcake Nov 8, 2018
    ShivamRathi, Nov 8, 2018 :
    Same problem here!
    Does anyone have solution for this???
    Thanks in advance
  3. gvamsi_krish Eclair Nov 8, 2018
    gvamsi_krish, Nov 8, 2018 :
    are you following this?
    Settings - System - System updates - Settings (top right corner icon) - Local upgrade - select downloaded package
  4. Ayyappa Pothula Donut Nov 8, 2018
  5. vriesdejoop Ice Cream Sandwich Nov 8, 2018
    vriesdejoop, Nov 8, 2018 :
    yes there is, did you not received the email? strange....
    zoran81 likes this.
  6. gvamsi_krish Eclair Nov 8, 2018
    are you also following this?
  7. S1541485816703 Cupcake Nov 8, 2018
    S1541485816703, Nov 8, 2018 :
    It can't be downgrade because of there is a new version is installed already! Beta 6 is the newer then 9.0.2.
  8. gvamsi_krish Eclair Nov 8, 2018
    Yes it is newer version, that's why the method is called 'downgrading' !! Theoretically it should work buddy..
  9. S1541485816703 Cupcake Nov 8, 2018
    It doesn't work.
  10. gvamsi_krish Eclair Nov 8, 2018
  11. S1541485816703 Cupcake Nov 8, 2018
  12. FaleshC KitKat Nov 8, 2018
    FaleshC, Nov 8, 2018 :
    because you are still using wrong file.
    RandomUserOne likes this.
  13. S1541485816703 Cupcake Nov 8, 2018
    I've downloaded from the link above.
  14. FaleshC KitKat Nov 8, 2018
    i am pretty sure its not the correct file. i have personally tested and downgraded so i know it works perfectly fine.
    does your filename contains downgrade in the name?
    also enable oem unlocking in developer settings, i didn't have to do it, it worked flawlessly for me.
    RandomUserOne and LegolasX like this.
  15. S1541485816703 Cupcake Nov 8, 2018
    File name: Plus6Oxygen_22_OTA_027_all_1810260000_bbefbe028ace46e5.zip
    Have you another link with a working file?
  16. FaleshC KitKat Nov 8, 2018
    this is not the file.
    you can use this link.
  17. shivpkapila Gingerbread Nov 8, 2018
    shivpkapila, Nov 8, 2018 :
    when taking the incoming calls phone doesn't give a vibrate. Does this is with my phone or someone else is also having the same issue ?
  18. E1508091245035 Cupcake Nov 8, 2018
    there is no file in the above link it is showing webpage error
  19. E1508091245035 Cupcake Nov 8, 2018
    yes iam following the same instructions but its not working.
  20. MMuralidhar Froyo Nov 8, 2018
    MMuralidhar, Nov 8, 2018 :
    Download from Open beta 1 Pie thread
    https://forums.oneplus.com/threads/oxygen-os-open-beta-1-for-the-oneplus-6.898938/
    Instructions for downgrading from Android P Beta version to MP version
    Rollback process:
    1. Download the latest ROM package from the specified server [HERE].
    2. Copy ROM rollback package to the mobile phone storage root directory.
    3. Settings -> system updates -> top right corner icon -> local upgrade -> click on the installation package -> immediately upgrade -> system upgrade to 100%.
    4. Select Reboot system now.
    5. Update successfully.
    Please note: This upgrade will clear all contents of the phone, please make sure to back up.
