272
OxygenOS Open Beta 6 for OnePlus 6
  1. YellowClaw Honeycomb Nov 18, 2018
  2. Kytharsis Marshmallow Nov 18, 2018
    Kytharsis, Nov 18, 2018 :
    I think your problem is really, really bad signal and the fact you're only charging it to 50%. Charge it up to at least 80% then use it normally.
    YellowClaw likes this.
  3. F1516513204353 Donut Nov 18, 2018
  4. YellowClaw Honeycomb Nov 18, 2018
    YellowClaw, Nov 18, 2018 :
    Signals are too weak...Android is searching for signals constantly as resulted in battery drain, either turn off the "sim 2" as it is not able to find any network. Secondly you're not even charging your cell. So it is hard to say about the battery drain you're facing.
    Kytharsis likes this.
  5. F1516513204353 Donut Nov 18, 2018
    F1516513204353, Nov 18, 2018 :
    Ok fine will try that. Not me but even my friends who use oneplus 6 downloaded the op6 9.0.2 update. They are facing battery issues and heating issues. Can't we like downgrade our phone's version?
  6. YellowClaw Honeycomb Nov 18, 2018
    Go to open beta 1 forum you will get the downgrade process there. I guess the cause of battery drain is also the "roaming".
    Maybe you're out on vacation where the signal network is weak.
  7. F1516513204353 Donut Nov 18, 2018
    There's no roaming here. It's just India Volte works.
    Also I was so happy with my oreo version.
    Check the temperature of my phone.
    So much heating problems.
  8. YellowClaw Honeycomb Nov 18, 2018
    9.0.2 is the most battery efficient update ever.
    You guys just don't know how to make it.
  9. YellowClaw Honeycomb Nov 18, 2018
    Than whats the "R" thing on your network ? LOL
  10. F1516513204353 Donut Nov 18, 2018
  11. Kytharsis Marshmallow Nov 18, 2018
    You know what "Roaming" means, right?
  12. YellowClaw Honeycomb Nov 18, 2018
    Yes but the signal varies if you're not in a particular state from where you bought your jio sim. That's why they say it's on roaming!
  13. F1516513204353 Donut Nov 18, 2018
  14. Deactivated User Nov 18, 2018
  15. YellowClaw Honeycomb Nov 18, 2018
    Kytharsis
    Help me god. [e]1f602[/e]
    I want to fly on mars.
    Lol no there will be "roaming" with couple of cupcakes [e]1f602[/e]
  16. F1516513204353 Donut Nov 18, 2018
  17. YellowClaw Honeycomb Nov 18, 2018
    Pie is better on signals as much as I've noticed.
    In oreo the speed and strength is little bit weak.
  18. F1516513204353 Donut Nov 18, 2018
  19. YellowClaw Honeycomb Nov 18, 2018
    first of all charge your phone. It takes only 45 minutes to charging 80-90%
    F1516513204353 likes this.
  20. F1516513204353 Donut Nov 18, 2018
