272
OxygenOS Open Beta 6 for OnePlus 6
  1. YellowClaw Honeycomb Nov 19, 2018
  2. YellowClaw Honeycomb Nov 19, 2018
  3. YellowClaw Honeycomb Nov 19, 2018
  4. YellowClaw Honeycomb Nov 19, 2018
    YellowClaw, Nov 19, 2018 :
    I manage to get 7-9 hrs SOT with the link i posted some pages above.
  5. Tclarke-94 Gingerbread Nov 19, 2018
    Tclarke-94, Nov 19, 2018 :
    the tweaks you shared though are things I basically do on every phone I have and I followed specifically on this device it's not really making that much difference I'm still getting 5-6 hours highest I've had is 7, on 9.0.2 I don't make it past 3 and a half to 4 though
  6. YellowClaw Honeycomb Nov 19, 2018
    My 10 hr SOT isn't going to be successful maybe.
  7. J1535518237687 Froyo Nov 19, 2018
    YellowClaw likes this.
  8. YellowClaw Honeycomb Nov 19, 2018
  9. YellowClaw Honeycomb Nov 19, 2018
  10. J1535518237687 Froyo Nov 19, 2018
    J1535518237687, Nov 19, 2018 :
    even i find it improved ...you flash clean everytime ?? clean installation anyways has better battery since it has no apps installed
  11. YellowClaw Honeycomb Nov 19, 2018
    yes clean flashed from scratch.
    Damn the OP6 beta 7 is becoming useless thread like OP6 9.0.2
    Chuck it.
    Kytharsis likes this.
  12. lsd2k Donut Nov 19, 2018
  13. G_sai_ram_QWvY Cupcake Dec 3, 2018
    G_sai_ram_QWvY, Dec 3, 2018 :
    Does mobile get affected if I change to beta versions ?
  14. pcoventry Honeycomb Mar 13, 2019
    pcoventry, Mar 13, 2019 :
    Does Android Auto work on Beta versions? I had to sell mine and get a S10 as I couldnt stand it being broken but my friend has a 6T and I am asking for her - as she is getting a new car with AA on it - and as we all know OP don't care to fix it with stable releases
  15. Fred1050 Donut Mar 13, 2019
    Fred1050, Mar 13, 2019 :
    pcoventry
    I use everyday AA with my OP6 openbeta [e]1f44d[/e][e]1f609[/e]
    There is some sporadic disconnections but it is not a real issue, it re-connect instantly
  16. O1539362690991 Eclair Mar 13, 2019
    O1539362690991, Mar 13, 2019 :
    bixice da pega
  17. pcoventry Honeycomb Mar 14, 2019
    pcoventry, Mar 14, 2019 :
    Well I upgraded and now i can't get back to stock. I download the downgrade zip pop it in root and I can't see it - I download the stable OTA zip and I can see it but I am told that I can't downgrade - so now this phone is worthless as I can't even sell it like this.
    It is faster than before - but AA is still broke.
  18. ironass KitKat Mar 14, 2019
    ironass, Mar 14, 2019 :
    I cannot believe that you are still on the 30th October 2018 Open Beta 6 release for the OnePlus 6 model, which is what this thread is about.
    I will assume that you actually mean the Open Beta 6 release for the OnePlus 6T that was released on Monday and that you wish to revert back from this to the stock, stable, OxygenOS firmware. In which case, read post #3 of...
    OxygenOS Open Beta 14 for the OnePlus 6 and Open Beta 6 for OnePlus 6T
    N.B. If you cannot open the above links in the OnePlus Community app, then open this in your web browser.
    pcoventry and Kytharsis like this.
  19. Y1537540350852 Froyo Mar 17, 2019
    Y1537540350852, Mar 17, 2019 :
    can anybody explain why my storage is so low..even though the music and picture and apps all are under 1.8gb each...and Android uses 12gb...so 64-(20gb max) = 46gb..
    I think at max 46 should be available to me ...
  20. pcoventry Honeycomb Mar 19, 2019
    pcoventry, Mar 19, 2019 :
    Thanks I will try that - I want to get back to stock but I do like the way this works so I am happy to stay on this for now.
