273
OxygenOS Open Beta 6 for OnePlus 6
  1. vriesdejoop
    Ice Cream Sandwich Nov 3, 2018
    vriesdejoop , Nov 3, 2018 :
    you are on stable, go to the stable treat, don't ask your question there but just read the two last pages, the answer is there at least 5 times
    in the whole threat at least 50 times
    YellowClaw likes this.
  2. YellowClaw
    Honeycomb Nov 3, 2018
    YellowClaw , Nov 3, 2018 :
    i guess 10000 times a same question has been answered in that thread. LOL
    vriesdejoop likes this.
  3. B_Wrath
    Nougat Nov 3, 2018
    B_Wrath , Nov 3, 2018 :
    Don't suggest something which is not required for Beta and doesn't work in general.
    Beta is not a staged rollout nor region based rollout. Using VPN does absolutely nothing.
  4. vriesdejoop
    no that's to much, there are ~2000 Post there so let's say 1000
  5. E1541232518340
    Cupcake Nov 3, 2018
    E1541232518340 , Nov 3, 2018 :
    Guys, my phones battery drains very fast on standby, oddly enough, the battery is great when phones screen is on, and i can get through 3-4 h of intense gaming without needing to charge the battery.
    I noticed the difference when i switched from the stables version 9.02 to open open beta 6
    Is it a bug? Should i switched back to the stable version?
    Anybody else having the same issue?
    I appreciate any advice from you guys.
  6. er.deepakcs
    Eclair Nov 3, 2018
  7. Divyanshu_Sankhwar
    Gingerbread Nov 3, 2018
    Divyanshu_Sankhwar , Nov 3, 2018 :
    wifi using 21% is strange
  8. gubro
    KitKat Nov 3, 2018
    gubro , Nov 3, 2018 :
    I think you should do a factory reset. See if that's the same after that.
  9. Rohitpande2009
    Eclair Nov 3, 2018
    Rohitpande2009 , Nov 3, 2018 :
    I did not receive any update on the studio lighting..
    I only got an update for the Night scape mode,
    but you have mentioned the update will contain studio mode. Kindly address this issue..
  10. Saurabh331
    Donut Nov 3, 2018
    Saurabh331 , Nov 3, 2018 :
    Getting issue with the recemt application slider woth navigation gesture. It keeps on scrolling between only 2 apps.
    Let me explain
    this is the first recent app
    2nd one
    next time it brings up the oneplus app which should not have come normally the app opened before the flipkart app should have opened. It should spiral through all opened apps not between 2 apps only.
  11. rameez.mannil
    Froyo Nov 3, 2018
    rameez.mannil , Nov 3, 2018 :
    Is there a problem connecting VPN apps?
    I tried Express VPN and Nord VPN.
    However, TurboVPN is working.
  12. gubro
    KitKat Nov 3, 2018
    Kindly read the second post of this thread. It is kindly explained . You could've kindly used the search function. I kindly answered and you should kindly say thanks for that.
  13. rameez.mannil
    Froyo Nov 3, 2018
    instead of wasting all the kindness in this world, you could have kindly pasted the link if your said reply here.
    search yielded nothing relevant for me.
  14. carlosfanini
    carlosfanini , Nov 3, 2018 :
    WiFi is consuming a lot of battery and that's not normal. Check to see if WiFi Scanning is ON and if it is, turn it off.
  15. gubro
    KitKat Nov 3, 2018
    You can't find the second post of this thread?
  16. rameez.mannil
    Froyo Nov 3, 2018
    Sorry mate, new in the community app. i thought your reply was for my query.
    by the time i realised, it was not, i couldn't find the option to delete the comment
  17. Maan gaur
    Cupcake Nov 3, 2018
  18. gubro
    KitKat Nov 3, 2018
    You did not get it because you are in the wrong thread.
    YellowClaw, zoran81 and Aks41179 like this.
  19. Maan gaur
    Cupcake Nov 3, 2018
  20. Aks41179
    Jelly Bean Nov 3, 2018
    Aks41179 , Nov 3, 2018 :
    You need to wait for updates to roll out globally.. Currently, it's staged roll out
