231
OxygenOS Open Beta 6 for the OnePlus 5
  1. idkwhoiam322
    Nougat Mar 13, 2018
    idkwhoiam322 , Mar 13, 2018 :
    Does your phone have USB Debugging switched ON! And no, the batch script should suffice!
  2. proharsh1
    Gingerbread Mar 13, 2018
    proharsh1 , Mar 13, 2018 :
    Yess. under the dev option i switched on the USB debugging.
  3. proharsh1
    Fault of old laptop? Coz when i tried using script it didnt show my phone "To connect" .
  4. idkwhoiam322
    Nougat Mar 13, 2018
    What does it say when you run the script?
  5. proharsh1
    Nothing,the command closes. Tried many times still unble to connect.!
  6. idkwhoiam322
    Nougat Mar 13, 2018
    Try the Java client then!
  7. proharsh1
    just have to download the java script and run on my laptop? or have to do something?
  8. idkwhoiam322
    Nougat Mar 13, 2018
    Probably need have but I don't know! Read that XDA thread and ask there if it hasn't been asked already!
  9. proharsh1
    Okayyy thanks bud :)
  10. MarthaMogudu
    Eclair Mar 13, 2018
    MarthaMogudu , Mar 13, 2018 :
    tried using vpn apps and changed locations to Canada and Germany but still it doesn't even show the update...
    how to update I'm impatient to wait
  11. idkwhoiam322
    Nougat Mar 13, 2018
    Try reading beyond the first option!!
  12. MarthaMogudu
    Eclair Mar 13, 2018
    well i can't wipe all my data
  13. idkwhoiam322
    Nougat Mar 13, 2018
    If you're worried about data loss, stay away from the beta! Data loss as a beta tester should be the least of your concerns! Another reason would be you're not reading properly at all which would be a major reason to stay away from the beta! None of the methods require a full wipe.
    MikeG247 likes this.
  14. Sachin jayaprakash
    Cupcake Mar 13, 2018
  15. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Mar 13, 2018
    NeVeR_SeTTLe , Mar 13, 2018 :
    Is your OnePlus launcher up to date from the Google Play Store?
    aakashsood likes this.
  16. Saurabh1239
    Saurabh1239 , Mar 13, 2018 :
    Automatic Incoming Call pick feature is good but requires a little modification.. Once on call waiting, another call should not be allowed to get connected with user action which means feature get disabled if there is call waiting..
    gowthammotox likes this.
  17. aakashsood
    Jelly Bean Mar 13, 2018
    NeVeR_SeTTLe likes this.
  18. Shubham Gilda
    Froyo Mar 13, 2018
  19. Padmanavo Roy Chaudhury
    Froyo Mar 13, 2018
  20. bgpancha
    bgpancha , Mar 13, 2018 :
    top and bottom of quick settings toggles has lot of wasted space and shorter space for notifications, kind of liked 8.0 style
