98
OxygenOS Open Beta 6 for the OnePlus 7 and OnePlus 7 Pro
  1. dhopmans
    Honeycomb Nov 21, 2019
    dhopmans , Nov 21, 2019 :
    You will never get answer because you post in the wrong thread. Go to the proper thread and ask it there. Not that you will get an answer anyway....
    subham_sekhar3112 and otto2 like this.
  2. Batman360
    OnePlus Accessory Tester Nov 21, 2019
    Batman360 , via OnePlus 7 Pro Nebula Blue , Nov 21, 2019 :
    What are you guys doing? Till when are you ygjys going to fix things instead of the features that are needed . And if you are fixing...then kindly fix the camera quality.. especially in potrait mode.
    Personalgroups likes this.
  3. dhopmans
    That's not a security feature it is a bug ;-)
    Z1574350319795 and LookedPath like this.
  4. K1566230500376
    Cupcake Nov 21, 2019
  5. Parallax. , via OnePlus 7 Pro Mirror Gray , Nov 21, 2019 :
    There is no "easiest way" to roll back to stable build without losing all of your data. I thought you've done your research before participating in an Open Beta build. You shouldn't expect the most stable build for your OnePlus device when you installed an Open Beta build, because this isn't what it was designed for. The aim for this whole Open Beta program is for you to report back any issues you've encountered to the OnePlus team, so that they can further refine their next stable release for OnePlus users.
    In short, when you installed an Open Beta build, you wholeheartedly agree that you are going to be one of many beta testers for the new features introduced to Oxygen OS.
    You lose the right to complain about its instability AND asking other people an easy way in reverting your device to a stable build without losing your data. You should have known the caveats that come with it when you participated in this program. Expecting that this program would work as well as the stable build is such a short-sighted view to have, and you regretting your decision to enter this program and wanting to pull back is of no fault of anyone other than yourself.
    Anyways, I'm pretty sure you're well-informed enough to know the conventional way to get back to stable build, so I'll leave you at that. Good luck with that.
    nashu@123, xnutzii, otto2 and 5 others like this.
  6. F1563425542790
    Parth0085 likes this.
  7. Parallax. , via OnePlus 7 Pro Mirror Gray , Nov 21, 2019 :
    No. All of your data that was in your phone would be carried over to the Open Beta build. However, it is not possible to do so if you decide to revert from the Open Beta to the stable build. Make sure you done your research before deciding to jump over to an Open Beta program. Too many people have joined the program, only for them to regret their decision later on.
    otto2 likes this.
  8. B k
    Ice Cream Sandwich Nov 21, 2019
    B k , via OnePlus 7 Pro , Nov 21, 2019 :
    no. ur data is safe.
    u have to download the ob6 zip file. use local upgrade
    if u have no issues in 10.0.2, then i would suggest stay.
    nothings much new in ob6, except u r using op7 and u want notch option. butit would be added in stable
  9. Q1569420069628
    Donut Nov 21, 2019
    Q1569420069628 , Nov 21, 2019 :
    I didn't get my security update till now [e]1f623[/e] what's going on there ? Is it only for some user?
    yshpll, M1546268560595 and S.Mondal like this.
  10. F1563425542790
    F1563425542790 , via OnePlus 7 Pro , Nov 21, 2019 :
    thanks for the answer. do you have the download linl for the open beta 6? the one on the website is beta 4
  11. Manishshandil01
    Donut Nov 21, 2019
    E1571039130047 and Alejandro196 like this.
  12. B k
    download oxygen updater app from play store
    it will be available on xda site too
  13. SuppNyUs
    SuppNyUs , via OnePlus 7 Pro , Nov 21, 2019 :
    Yup, same here, maybe he didn't flashed the ROM properly ?
    mptpro likes this.
  14. B k
    and u r on version ??
  15. #35
  16. Q1569420069628
    Donut Nov 21, 2019
  17. X1571968158338 , via OnePlus 7 Pro , Nov 21, 2019 :
    guys, the battery consumption has increased significantly again and heating up issue is back. finding it very very frustrating. please please please resolve this issue quickly. Google Play services again seems to be consuming battery like hell. please do something on this at the EARLIEST!!!!!!
  18. B k
    beta 5 and 10.0.2 gives u October security patch
    beta 6 comes with November.
    if u r on older version of oxygen os, update it
    #38
  19. B k
    play services are hell of a problem
    sometimes it seems fine, and sometimes it f*** battery.
    try clearing cache of play services, it works.. atleast for me yes
    #39
  20. B k
    either wait for ota
    or
    download from oxygen updater/xda site,, links r available
    if u r using oxygen updater, select incremental update
    #40
