91
OxygenOS Open Beta 6 for the OnePlus 7 and OnePlus 7 Pro
  1. B k
    Ice Cream Sandwich Dec 3, 2019
    B k , via OnePlus 7 Pro , Dec 3, 2019 :
    find OPwallpaper Resources in apps and notification, and delete it.
    download latest OPwallpaper Reaources apk from apkmirror and install it.
    dont set wallpapers. first restart ur phone then set walls
    [e]1f609[/e][e]1f44d[/e]
  2. G_Ashwin_J_cRIy
    Cupcake Dec 3, 2019
    G_Ashwin_J_cRIy , Dec 3, 2019 :
    Open beta 6 is causing batter draining and some apps are crashing up. open beta 5 was a better build. hope you release open.beta 7 with all the bug fix. also charging time is more compared to earlier. Inside applications settings clearing the app cache doesnt work .it only works when you force stop the app and then clear the app cache
  3. AndiTheBassman , via OnePlus 7 Pro , Dec 3, 2019 :
    I don't know why there is such a difference but I get more out of the battery with beta 6 than with any other previous version. Over the weekend I my phone went 44 hours without a charge and with normal use (I charged to 100% a couple of times and turned ram boost of, battery optimizations are turned off as well)
  4. AndurianSM
    Cupcake Dec 3, 2019
    AndurianSM , via OnePlus 7 Pro , Dec 3, 2019 :
    On my 7 Pro with beta 6 battery life is very good but ram management is poor.
  5. perooo2
    Donut Dec 3, 2019
  6. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 3, 2019 :
    Betas approx every second week.
    Stable 1 per 1-2 months.
    Security updates is normally bi-monthly.
    perooo2 likes this.
  7. idbl_fanatic1
    idbl_fanatic1 , Dec 3, 2019 :
    I am on Android 9, Aug 1 security patch, so they are now 4 mos behind on security patches
  8. Nic2112
    Nic2112 , via OnePlus 7 Pro , Dec 3, 2019 :
    They won't be updating security for Android 9 anymore.
    anubis72 likes this.
  9. idbl_fanatic1
    That makes sense, then they need to get 10 out (stable)
    Georgeoneplus7pro likes this.
  10. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 3, 2019 :
    The only 9 based devices in 7 series that I've seen still get security updates is some of the 5G versions (hopefully all of them).
    T-mobile users SHOULD have gotten security updates since they haven't released 10 at all yet. But as far as I seen they haven't recived any security updates and I wonder what is stopping them...
    Normal unlocked 7 series has 10 and has stopped updating 9. However since they still seem to be rolling out 10 to some who are stuck on 9 (especially in US) it kind of looks abit bad...
    idbl_fanatic1 likes this.
  11. Costa_Veloso
    Cupcake Dec 3, 2019
  12. idbl_fanatic1
    Well I haven't gotten it yet, and from what I have read there are some issues, I don't want to use the updater.
  13. patpilus
    Cupcake Dec 3, 2019
    patpilus , Dec 3, 2019 :
    I have to repeat the question sure to no answer: does beta 6 contains fixes for 3rd party chargers like in 10.0.2 stable?
    I have tested Power Delivery chargers and none of them are charging at 5V/3A. 2A is actually maximum I can get.
  14. Costa_Veloso
    Cupcake Dec 3, 2019
    Costa_Veloso , via OnePlus 7 , Dec 3, 2019 :
    Oh you have that T-Mobile version? For international versions, European versions etc it's already out through OTA or official website of OnePlus
  15. idbl_fanatic1
    Nope, unlocked from OnePlus
  16. Costa_Veloso
    Cupcake Dec 3, 2019
    It's very weird..try to download the update from website and install it. May there is a server issue
  17. idbl_fanatic1
    I do see the 10.1 on the website, I just want to verify that this will just update, not wipe going from 9-10? (Stable)
  18. Costa_Veloso
    Cupcake Dec 3, 2019
    Yes of course,my friend. It's doesn't wipe something
  19. idbl_fanatic1
    Here goes nothing...........................
    Well, so far so good.............
  20. Costa_Veloso
    Cupcake Dec 3, 2019
