98
OxygenOS Open Beta 6 for the OnePlus 7 and OnePlus 7 Pro
  1. DMaarten
    Honeycomb Dec 4, 2019
    DMaarten , Dec 4, 2019 :
    What?
    drewpoc likes this.
  2. AzuLa9713
    Honeycomb Dec 5, 2019
  3. DMaarten
    AzuLa9713 likes this.
  4. N1564289688785
    Cupcake Dec 5, 2019
  5. DMaarten
  6. K1560650362069
    Cupcake Dec 5, 2019
    K1560650362069 , Dec 5, 2019 :
    my mobile not able turning on data when i turned on...i was doing it by tuning the aeroplane mode on and off so that it is getting ready....plz do something
  7. saikiran4ever
    Jelly Bean Dec 5, 2019
    saikiran4ever , Dec 5, 2019 :
    Reset access points for that sim.
  8. G_Yugal_Kukde
    Eclair Dec 5, 2019
  9. wawanredblack
    Gingerbread Dec 5, 2019
  10. Lguzman19
    Donut Dec 5, 2019
    Lguzman19 , via OnePlus 7 Pro , Dec 5, 2019 :
    phone is heating up consistently causing battery drain. intellegent control on the battery optimization seems to be flawed and have major issues.
    maxsinghania likes this.
  11. akks
    KitKat Dec 5, 2019
    akks , Dec 5, 2019 :
    Don't get the point of monthly security patch. Why everyone is bothered about security patch this much? OnePlus update schedule had been always bi-monthly security updates. Anything extra is mere bonus. Monthly security patches are there only for pixel devices and android one devices as far as I know. A regular user won't be that much affected by security issues, even if their security patch is outdated.
    SubySTI23 likes this.
  12. Anoop_14
    Froyo Dec 5, 2019
    Anoop_14 , via OnePlus 7 , Dec 5, 2019 :
    I'm really satisfied with OB6, till 30th Nov my OP7 was running on so called stable update 10.0.2. I don't know how many software engineers are here in this community who are continuosly posting about the unstability of android 10 OB6 for OP7/7pro. but as a normal user I have been not facing any big issue with OB6 except a few which are quit acceptable and normal users i don't think will complaint about those bugs. one thing most of the OB6 users are complaining is battery issue. these guys are continuously stressing on this issue as if they their phones battery is draining from 100 to 0 within 1 or 2 hour. if I compare battery draining of OB6 with Pie i would say the difference is not more than 5%. I play COD Mobile i have most of the social media apps which are continuously active in background, my location is always on, i use MI Band 3 so my OP7's bluetooth is also continuously on. In office hours most of the time I use my phone's internet in my laptop via Hotspot. I would say I'm also a kind of heavy user of phone. AND I'M VERY MUCH SATISFIED WITH OB6.
  13. charmingash
  14. Ultraman215
    Ultraman215 , Dec 5, 2019 :
    Most people now days have more sensitive data on their phones than they do on their computers...
    If Google is actively remediating their OS to mitigate the vulnerabilities in the software, then a reasonable person would expect to receive those patches ASAP.
    Bad guys are actively looking for any way to exploit the vulnerabilities either for financial gain or simply for fun.
  15. Ultraman215
    Based on this, what do you think is the delay in getting this code base out of beta?
  16. Ultraman215
    Could this be a machine learning issue that takes a bit of time to optimize?
  17. akks
    KitKat Dec 5, 2019
    I accept. But no other OEMs push monthly security patches other than Google's own pixels and Android One devices. If so, every other android user is at risk. Then those who save that much sensitive datas in their phones should then consider buying such devices only. OnePlus is even otherwise infamous for data breach;)
  18. JIMMMEHHHH
    Cupcake Dec 5, 2019
    JIMMMEHHHH , via OnePlus 7 Pro , Dec 5, 2019 :
    Anyone having issues with calls dropping? I've got the 7 Pro GM1913 unlocked using EE in the UK. switched from 10.0.2 to Beta 6 but the problem persists across both stable and beta versions. Outgoing calls cut off after 20 seconds but sometimes can stay connected for a couple of minutes. Tried with WiFi calling, VoLTE, WiFi disabled and data disabled but still having the same issues. Rebooting and wiping caches doesn't seem to make a difference either
    Anyone able to shed some light?
  19. G_Yugal_Kukde
    Eclair Dec 5, 2019
    G_Yugal_Kukde , via OnePlus 7 , Dec 5, 2019 :
    was not aware of that until now and they dont even bother about it.
    But I am very conscious about my security and everyone should be.
