98
OxygenOS Open Beta 6 for the OnePlus 7 and OnePlus 7 Pro
  1. UnsereErde
    Donut Dec 12, 2019
    UnsereErde , Dec 12, 2019 :
    I never had problems like this. Have you tried to factory reset?
  2. [email protected]
    Honeycomb Dec 12, 2019
  3. Gangester
    Eclair Dec 12, 2019
    Gangester , via OnePlus 7 Pro , Dec 12, 2019 :
    I wanted to factory reset but I can't
    I have so many important files that I will lose and some important apps that if lose them I can't install them again ( like bank apps from other countries that requires you to get the activation code physically from them )
    fcarmona likes this.
  4. Franzie3
    Froyo Dec 12, 2019
    Franzie3 , Dec 12, 2019 :
    I'll be honest, if this is your situation, you probably shouldn't be in beta then. That is part of the risk of running Beta. If you have that many important files you can back them up to the cloud or something but bank apps that have those requirements i'd probably not stay in a beta for.
    Oneyedmonkey and Gangester like this.
  5. fcarmona
    Gingerbread Dec 12, 2019
    fcarmona , Dec 12, 2019 :
    use Migrate
    You need root
    Gangester likes this.
  6. DMaarten
    DMaarten , Dec 12, 2019 :
    Oh yes, days ago. It's amazing! Does my laundy and everything!
    We just keep it quiet to pick on people here :p
  7. Gangester
    Eclair Dec 12, 2019
    it's not that big of a deal for me
    I like the OB, I like the risk 😅
    I just wanted to say my problems so it might help the developers with the next OB
    but thanks for the advice [e]1f60a[/e][e]1f44c[/e]
    OnePlusAim likes this.
  8. Georgeoneplus7pro
    Jelly Bean Dec 13, 2019
    Georgeoneplus7pro , Dec 13, 2019 :
    Follow your intuition and open your mind.
  9. CHETHANGV2
    Froyo Dec 13, 2019
  10. Mamluk
    Froyo Dec 13, 2019
    Mamluk , via OnePlus 7 , Dec 13, 2019 :
    wait for OB 7, download and install...your current OS version is newer than what you are trying to install...it doesn't work this way...
  11. CHETHANGV2
    Froyo Dec 13, 2019
    CHETHANGV2 , via OnePlus 7 Pro , Dec 13, 2019 :
    Thanks for solution
  12. charmingash
    Honeycomb Dec 13, 2019
  13. z953rr
    Froyo Dec 13, 2019
    TimNv likes this.
  14. Pa_One
    Eclair Dec 13, 2019
    Pa_One , Dec 13, 2019 :
    Rise to wake isn't working properly?
    tap to wake / double tap to wake isn't working while in a call
    J1571092570140 likes this.
  15. MartinRo
    Gingerbread Dec 13, 2019
    MartinRo , via OnePlus 7 , Dec 13, 2019 :
    Most likely the Test in closed Beta has shown some issues they still try to fix. closed Beta Version will become a open beta when closed beta users are happy
    DMaarten likes this.
  16. wawanredblack
  17. arturcrackgv
    Eclair Dec 13, 2019
  18. Rhondon_Sama
    Froyo Dec 13, 2019
  19. H1570196076554
    Donut Dec 13, 2019
    H1570196076554 , Dec 13, 2019 :
    bro download oneplus updater app
