98
OxygenOS Open Beta 6 for the OnePlus 7 and OnePlus 7 Pro
  1. Mikael82
    Cupcake Dec 18, 2019
  2. Anoop_14
    Eclair Dec 18, 2019
  3. arturcrackgv
    Eclair Dec 18, 2019
  4. alami.shayan
    Froyo Dec 18, 2019
    alami.shayan , Dec 18, 2019 :
    For god sake when one person informs everyone about the update release you don't have to inform and post again, with this heavy screenshots and stuff.
    Covrivov likes this.
  5. Russel.lopes
    Froyo Dec 18, 2019
  6. Alvaroizad
    Donut Dec 18, 2019
    shahidps likes this.
  7. DanielSun1981
    Donut Dec 18, 2019
  8. pyroset
    Gingerbread Dec 18, 2019
    N1573598014867 likes this.
  9. arturcrackgv
    Eclair Dec 18, 2019
  10. HARISH263
    HARISH263 , via OnePlus 7 , Dec 18, 2019 :
    open beta 7 is out and only one feature is added
    optimize charging in battery section
  11. fcarmona
    fcarmona , Dec 18, 2019 :
    Beta 7 is out
    use the oxigen updater app
  12. pyroset
  13. DMaarten
    Honeycomb Dec 18, 2019
    DMaarten , Dec 18, 2019 :
    And the fixes
    And the optimizations to the ram management
  14. TheMysticalShaman
    TheMysticalShaman , via OnePlus 7 Pro , Dec 18, 2019 :
    There is a very persistent bug. The bug was created with open beta 6 and continues in open beta 7. You customize. You turn on override force-dark. You turn off over-ride force dark. You lose your customizations. As they go back to default. Basically, if you use override for. You can't customize. As you lose it as you switch between off and on. Very a.
  15. TheMysticalShaman
    Annoying
  16. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 18, 2019 :
    Just got the update. The cat died and house burnt down... Otherwise OK [e]1f609[/e] (kidding... Just to be sure...)
    I'm assuming the new battery function is AI based "finish charging timer". In other words doing the last part of charing at wakeup time... Or similar. Had this function on a Sony device once. It charged up to 80% or so. And then finished it of at a certain time before the time it thinks you will unplug.
    Or someone else have a better idea?
  17. arturcrackgv
    Eclair Dec 18, 2019
  18. kmaier
    kmaier , via OnePlus 7 , Dec 18, 2019 :
    well a delayed one so can cry where is my update and then when it comes we cry I want to roll back because of all the 'bugs'. it's obvious isn't it?
