98
OxygenOS Open Beta 6 for the OnePlus 7 and OnePlus 7 Pro
  1. caultpira
    Cupcake Dec 18, 2019
  2. Alvaroizad likes this.
  3. Nonochiken47
    Froyo Dec 18, 2019
  4. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 18, 2019 :
    If your bootloader is locked just use the normal incremental. Should show up the normal way pretty fast. Got it a few minutes ago myself
  5. Nonochiken47
    Froyo Dec 18, 2019
  6. SuppNyUs
    Honeycomb Dec 18, 2019
  7. Nonochiken47
    Froyo Dec 18, 2019
    Nonochiken47 , Dec 18, 2019 :
    yes but for better battery life and performance what is better??
  8. charmingash
  9. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 18, 2019 :
    The incremental patches stuff already existing on phone to make it identical to the full update. The reason for full update, besides unlocked bootloader and root, would be if change from stable to beta or having skipped a a few updates so an incremental was never created. Performance or battery wise it should not matter.
  10. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 18, 2019 :
    I never needed to wait longer then 30 minutes after first post of update on my device before an OTA showed on mine.
    Nothing found if you do a manual search?
  11. G_F._Anton_KFBw
    Eclair Dec 18, 2019
  12. charmingash
    charmingash , via OnePlus 7 , Dec 18, 2019 :
    i wanna convert from stable to beta 10.0.3 was such a noob update particularly global one.
  13. SuppNyUs
    SuppNyUs , via OnePlus 7 Pro , Dec 18, 2019 :
    Yes but if you run a stable version then you will not receive it in OTA, so people need it.
  14. Nonochiken47
    Froyo Dec 18, 2019
    Swejuggalo
    The incremental patches stuff already existing on phone to make it identical to the full update. The reason for full update, besides unlocked bootloader and root, would be if change from stable to beta or having skipped a a few updates so an incremental was never created. Performance or battery wise it should not matter.​
    Ok thanks 😀
    Demon_hunter likes this.
  15. Nic2112
    Ice Cream Sandwich Dec 18, 2019
  16. donPepitoGrillo
    donPepitoGrillo , Dec 18, 2019 :
    If the feature is like you said, I'm thinking about: what happens with code optimization that Android usually performs when battery is 100% charged and idle?
  17. SuppNyUs
  18. VIJAY216
  19. faizbodle
    Froyo Dec 18, 2019
  20. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 18, 2019 :
    If it acts like that it should hopefully fully charge within a reasonable timeframe leaving enough time for such things (my Sony more or less became mad at me and hardly ever triggered that charge function. "he is too random. Let's ignore him" it said and never showed up eventually...) . Even if you could possible missout a few times the important thing is that is gets time to do sometimes. I highly doubt you end up preventing it so often that it starts to be a problem.
    But it's just speculation.
    donPepitoGrillo likes this.
