77
OxygenOS Open Beta 7 for the OnePlus 7 and OnePlus 7 Pro
  1. X1569083403239
    Cupcake Dec 26, 2019
    X1569083403239 , Dec 26, 2019 :
    that's probably sums it up...
  2. Azzlan
    Donut Dec 26, 2019
    Swejuggalo likes this.
  3. G_Leon00047
    G_Leon00047 , Dec 26, 2019 :
    Hello everyone, using OnePlus 7 Pro I've noticed that after installing the newest beta update my phone is draining sooo much faster. Not only in general use but overnight I'm losing upwards of 35% with my screen off which is just crazy, anyone else having this issue?
  4. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 26, 2019 :
    Must be something in the battery stats. How does it look there (both apps and full device usage)?
  5. G_Leon00047
    I looked at it this morning and everything looks pretty normal, says "Apps are running normally" and checking usage stats shows a steady straight line decline saying my device should be dead by 5:30 which is weird (previous versions with moderate use I'd have about 40% getting home). I turned off optimized charging and I'm going to see if that makes any difference, I don't mind if my battery charges slightly slower if it drains slower as well.
  6. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 26, 2019 :
    Some app or activity must keep the phone awake constantly if no app is draining more than usual. Nothing strange at all in both areas of the battery stats?
    Most people guess of that charge option is to minimize the time the phone is at 100% and on the charger. No point in quick charging if the phone "knows" it is going to be connected for 8 hours. If my guess is right it could hold the phone at 80/90% and finish in a decent time before you normally disconnect.
    App drain is one thing but full device usage an other.
    My app drain looks like this.
    With BetterBatteryStats I get alot more info. So this is what I use when I want to investigate and app issue. Huge amount of partial wakelocks means trouble usually.
  7. Steven_Petrillo
    Gingerbread Dec 26, 2019
    Ash_Patil and KStonkus like this.
  8. vriesdejoop
    Ice Cream Sandwich Dec 26, 2019
    vriesdejoop , via OnePlus 7 Pro , Dec 26, 2019 :
    it's back for me to, but only with NFC turned on. it's also back in version 10.3.0 with NFC on, so you can report it through feedback
  9. I1568603958567
    Cupcake Dec 27, 2019
    I1568603958567 , Dec 27, 2019 :
    Hi
    I am facing phone slowness and charging issue after the latest update. Phone is slow now and charging takes more time than usual. I've plugged in for 15 minutes and phone charged only 8%. Can somebody help on this.
    regards
    nivin.
    Poovaragavan22 likes this.
  10. Arun_Kashyap
    Gingerbread Dec 27, 2019
  11. MaJa1969
  12. MaJa1969
  13. MaJa1969
  14. ajinasokan
    MaJa1969 likes this.
  15. J1570642150840
    J1570642150840 , Dec 27, 2019 :
    the hide notch feature is not good like before bcoz the notification window also comes into the display while before they remain in notch area even when you hide the notch
  16. MaJa1969
