77
OxygenOS Open Beta 7 for the OnePlus 7 and OnePlus 7 Pro
  1. Sopheak_Noun
    Froyo Jan 2, 2020
    Sopheak_Noun , via OnePlus 7 Pro , Jan 2, 2020 :
    Hi admin. after the 10.0.2 release i found the dual 4G and force VoLTE function is not working. currently i try the beta 7 also having the same issues. possible may you add the VoLTE support for all Cambodia carrier network. sofar we found others brand is supported even the mid-range phone.
  2. G_ik1llpeeple4fun_KWAF
    Froyo Jan 2, 2020
  3. Areebanwar
    Ice Cream Sandwich Jan 2, 2020
  4. AnonymousWP
    The Lab - OnePlus 7 Pro Reviewer Jan 2, 2020
    AnonymousWP , Jan 2, 2020 :
    It seems like a new beta is rolling out. Can anyone confirm? I'm adding it to Oxygen Updater but I don't have a changelog yet.
  5. KeepTransisting
    KeepTransisting , Jan 2, 2020 :
    Confirmed. Beta 8 is available for download. A whopping 2.1 gigs
    XRaptor29 and AnonymousWP like this.
  6. AnonymousWP
  7. FIROZ77
    Eclair Jan 2, 2020
  8. Vasanthdhawan
    Cupcake Jan 2, 2020
  9. Atanu Maji
    Honeycomb Jan 2, 2020
    the_reckoner likes this.
  10. AnonymousWP
    That's because it is indeed the full ZIP and not the incremental package. It's the whole OxygenOS-file.
  11. sanju103
    Cupcake Jan 2, 2020
  12. akks
    KitKat Jan 2, 2020
    akks , Jan 2, 2020 :
    From the changelog, it looks like a minor bugfix update only, with December security patch. Still, as the full zip is being released, some serious bug is fixed! 😜😁
  13. wospino
    wospino , via OnePlus 7 Pro , Jan 2, 2020 :
    OnePlus Is compatible with VoLTE but not all carriers are certified for OnePlus, due you need to force VoLTE to work with your device... it's possible that you have noise on your VoLTE calls because using a generic VoLTE configuration...
    with this in mind now you have the opportunity to do a choice if you force VoLTE or not
  14. arvinmradze
    arvinmradze , Jan 2, 2020 :
    Beta 8
    Changelog
    System
    • Optimized the mistouches when the phone was in a pocket
    • Fixed the display issue on the uninstalling page
    • Updated Android security patch to 2019.12
    • Improved system stability and general bug fixes
    Camera
    • Fixed the crash issue while opening the app
    • Fixed the black screen issue
    Download
    •OP7 - Global
    https://otafsg1.h2os.com/patch/amaz....W.21_OTA_021_all_1912261302_440adb0e0649.zip
    •OP7P -Global
    https://otafsg1.h2os.com/patch/amaz....21_OTA_021_all_1912261255_76782007d7dbec.zip
    VaibhavBhargava likes this.
  15. AzuLa9713
  16. Poovaragavan22 , via OnePlus 7 Pro Mirror Gray , Jan 2, 2020 :
    is it working
  17. Rishabh1525
    Eclair Jan 2, 2020
    Rishabh1525 , via OnePlus 7 Pro , Jan 2, 2020 :
    An immediate bug noticed on Beta 8. Even after you hide the bottom bar from the gesture settings, once you open the keyboard, it appears. And the keyboard has this weird arrow to minimize
    Sagarshaikh and DMaarten like this.
  18. DMaarten
  19. TheMysticalShaman
    TheMysticalShaman , via OnePlus 7 Pro , Jan 2, 2020 :
    Open Beta 8 is now available. Still having a problem when I enable override force-dark, when I disable override force-dark, my customizations revert back to default. Only way to keep my customizations is not to use override force-dark which I do need. So I have to sacrifice customizing in favor of override force-dark. I can't have both. It would be too much hassle to set my customizations several times a day.
