77
OxygenOS Open Beta 7 for the OnePlus 7 and OnePlus 7 Pro
  1. Rockingbks
    Gingerbread Dec 19, 2019
    Rockingbks , Dec 19, 2019 :
    ultra power saving mode is much required when your battery goes below 5 percent. Samsung phones can last for hours in Ultra power saving mode.
    #81
  2. VaibhavBhargava
    Lollipop Dec 19, 2019
    VaibhavBhargava , Dec 19, 2019 :
    It's not the intended behaviour as "Hide the bottom bar" is disabled. This option was added from OnePlus's side.
    The bottom bar represents the home button, which still has a purpose even on home screen, that is to go back to the main home screen.
    #82
    Atanu Maji likes this.
  3. VaibhavBhargava
    You can submit your suggestions via the feedback.
    Personally I don't see any reason why would I keep using my phone to it's death, when I think I am in a emergency situation.
    #83
  4. SATISH.D.S
    #84
  5. A.r.u.n_R
    Froyo Dec 19, 2019
    #85
  6. Swejuggalo
    Community Bug Hunter Dec 19, 2019
    #86
  7. A.r.u.n_R
    Froyo Dec 19, 2019
    A.r.u.n_R , via OnePlus 7 , Dec 19, 2019 :
    thanks, I checked it earlier. I was able to see that there was an update with the above mentioned changelogs, wasn't getting the download option as I'm on stable. just checked the app before I read your reply and to my pleasant surprise, they have just launched a stable update with hide notch feature. 🙂
    #87
  8. ashutoshsingh577 , via OnePlus 7 Pro , Dec 19, 2019 :
    Swejuggalo
    What beta did you download?
    If you installed 10.3.0 there is no beta that is newer. 10.3.0 is dated 14 Dec. Beta 7 is 11 Dec.
    You would need to rollback with a downgrade file first to be able to use beta 7. That would mean a full wipe.
    Just curious, why beta? I'll do it since it's fun. Not because of a special feat or something.​
    Stable version is 10.0.3
    #88
  9. Swejuggalo
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 19, 2019 :
    Wide rollout this time. 10.3.0 on 7T/7/6T/6. Impressive.
    #89
    S1511181212139 likes this.
  10. Swejuggalo
    Betas is simply called Beta 1,2.... And now 7. 10.0.3 was last stable. New stable is 10.3.0. If you already installed 10.3.0 you currently installed OS is newer then the newest beta
    #90
  11. Miskaj
    Eclair Dec 19, 2019
    Miskaj , Dec 19, 2019 :
    New beta 7 broke lte and mobile data
    Updated last night and after that I have noticed really weird problems with mobile data
    -Almost every app is now unusable, I get a error message saying that I dont have internet access (i have full bar 4g)
    -I still get normal notifications. For example I receive a notification for an email but i cannot open it, it just says that i dont have internet access.
    -oddly enough whatsapp and telegram work
    #91
  12. man_abhi
    #92
  13. OnePlusAim
    Honeycomb Dec 19, 2019
    OnePlusAim , via OnePlus 7 Pro , Dec 19, 2019 :
    I'm having the best battery I've had so far
    #93
    roryrudy likes this.
  14. OnePlusAim
    sometimes a refresh is necessary doing a hard reset often fixes these issues or you could Fastboot flash boot Modem.img
    #94
  15. Miskaj
    Eclair Dec 19, 2019
    Yeah im getting emotionally ready cause i hate setting up my phone from scratch :D
    #95
    OnePlusAim likes this.
  16. OnePlusAim
    trust me I understand. With how unlocked and easy to root this phone is I've soft bricked it a bunch XD I've probably gone through the process of resetting up my phone 100+ times in about 5 months XD but I like to play
    #96
  17. BlueSwede
    Froyo Dec 19, 2019
    BlueSwede , Dec 19, 2019 :
    they copied it from Pixel launcher.
    Before flashing OB7 I was running Pixel Experience on my OP7Pro and that is how it works on the Pixel.
    Maybe they're trying to prevent screen burn-in.
    When you turn on the "hide bottom bar" switch in settings you lose functionality: the "force screen rotation" toggle that shows up when you rotate your phone doesn't appear anymore..
    plus the bottom bar is just a visual indicator. Even if it never existed you'd still know that it serves as a gesture sensitive area to navigate your phone. That is how OnePlus's own gestures work: no indicator at all, but you still know it is there.
    I'm totally fine with them removing it.
    #97
  18. oneplusfanf4ever
    Froyo Dec 19, 2019
    oneplusfanf4ever , via OnePlus 7 , Dec 19, 2019 :
    ootko suomalainen? oli sama ongelma osaan auttaa täs ehkä!
    #98
  19. Atanu Maji
    Atanu Maji , via OnePlus 7 Mirror Gray , Dec 19, 2019 :
    Just because you didn't receive the update the earliest doesn't mean it wasn't out. I got it on 18 December evening.
    And yeah though battery soc is average if not poor, roughly get 5 hours in moderate usage no game installed.
    #99
  20. Miskaj
    Eclair Dec 19, 2019
    oon joo, kerro vaa jos osaat auttaa
    guerrasantos9@gm likes this.
