77
OxygenOS Open Beta 7 for the OnePlus 7 and OnePlus 7 Pro
  1. superplus
    Head Moderator Head Moderator Dec 20, 2019
    superplus , Dec 20, 2019 :
    Hi, you posted this in the security program announcement thread. I have moved them here based on your previous postings in OP7/7Pro update threads, since you didn't specify your device or other such information. As per the start post of any update thread, other than posting in thread, you can submit software bug reports through the community app or at the feedback forums (https://forums.oneplus.com/feedback/).
    F_Curtis_Owens_exfg likes this.
  2. BadGuyGenius
    Froyo Dec 20, 2019
    BadGuyGenius , Dec 20, 2019 :
    I apologise for that
    superplus likes this.
  3. Pranjal.Goel.16 , via OnePlus 7 Pro Mirror Gray , Dec 20, 2019 :
    I have a major problem with oxygen os after from Android 10, that it does does not give option to unlock apps with fingerprint while using split screen. Please guys report this issue, I'm tired to reporting OnePlus is not replying.
    OnePlusAim likes this.
  4. roryrudy
    Gingerbread Dec 20, 2019
    roryrudy , via OnePlus 7 Pro , Dec 20, 2019 :
    First time I'm commenting on an Open Beta thread and I must say I had to. For the first time, I uninstall GCam. The stock camera is now really reliable. I don't know what they did but it is working. Battery life seems better but I will test some more.. Overall I'm pleased with beta 7.
  5. OnePlusAim
    Honeycomb Dec 20, 2019
    OnePlusAim , via OnePlus 7 Pro , Dec 20, 2019 :
    Right on My Dude I've noticed better battery life as well
    roryrudy likes this.
  6. baggz143
    baggz143 , via OnePlus 7 Pro , Dec 20, 2019 :
    how do i get it without oxygen updater or xda?
    I'm on OOS 10.0.2 right now
  7. aholaR
    Cupcake Dec 20, 2019
    aholaR , Dec 20, 2019 :
    I have a serious network issue on cellular connections when updated Beta 7.
    At The moment only Wifi and Bluetooth working.
    G_Fanny_Renvall_KvFN likes this.
  8. F_Sami_Holopainen_Mwuy
  9. S@mmed007
    S@mmed007 , Dec 20, 2019 :
    I was on OnePlus 7 beta. But now i have installed a stable update. I have moved it in internal storage. But i am not able to find anything in local upgrade.
  10. I1562869506998
    I1562869506998 , via OnePlus 7 Pro , Dec 20, 2019 :
    I am also facing the network issue since last 3 days..
  11. rohannaik162
    Donut Dec 20, 2019
  12. G_Fanny_Renvall_KvFN
  13. G_Fanny_Renvall_KvFN
  14. Swejuggalo
    OnePlus 9 Series Expert Community Expert Dec 20, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 20, 2019 :
    Made sure the file is a zip and not zip.jar?
  15. Swejuggalo
    Tried to replicate this. This is what I had opened.
    And it unlocked just fine with fingerprint. Tried 3 times. Worked every time.
    S@mmed007 likes this.
  16. Swejuggalo
    Tried to reset APN?
    Or reset wifi, mobile and bluetooth?
  17. Swejuggalo
  18. Swejuggalo
  19. Swejuggalo
    What fix exactly? The left/right pill slider at the bottom?
