170
OxygenOS Open Beta 7 (MM) for OnePlus 3
Thread Status:
Not open for further replies.
  1. destronije
    Donut Nov 17, 2016
    8ouvou likes this.
  2. miikapk
    Donut Nov 17, 2016
    miikapk , Nov 17, 2016 :
    Have you actually tried to have .mid or .midi set for example as a Clock app tone? I granted storage permission to Clock app and no difference. All points it being a simple configuration issue in the OS ringtone picker.
  3. SMudassar121
    Honeycomb Nov 17, 2016
    SMudassar121 , Nov 17, 2016 :
    Hey. Can anyone clarify? What's difference between "Community builds" (like 3.5.5) and "Open Beta Build" ( like 7). Just.launched. both are same?
  4. sahirhussain
    sahirhussain , Nov 17, 2016 :
    3 finger swipe for screenshot is what i use. took full 2 days to adjust to this method after they removed the functionality from the power button.
  5. prisacariuadi
    Jelly Bean Nov 17, 2016
    prisacariuadi , Nov 17, 2016 :
    i confirm this....really sucks
  6. alwayswynne
    Gingerbread Nov 17, 2016
  7. lucifer_angel
    lucifer_angel , Nov 17, 2016 :
    android system battery drain is gone or still there?
    because this was most serious issue in last build 3.5.5!!
  8. prisacariuadi
    i encountered the same problem whaen trying to activate AdAway....not enough space on system partition
    yolomofo and 8ouvou like this.
  9. Umbrecht
    Cupcake Nov 17, 2016
  10. jmarcosk
    jmarcosk , Nov 17, 2016 :
    This is not only doze... there is a task killer there, it was killing my Nova Launcher...
  11. simonone
    simonone , Nov 17, 2016 :
    Sorry, you are right. Permission needed to select Local ringtones, but does not allow midi files even though they play OK with system music app.
    miikapk likes this.
  12. simonone
    It's the new aggressive doze and app hibernation - apps can be excluded in settings/battery/menu>aggressive doze & app hibernation
  13. abhi77kumar
    abhi77kumar , Nov 17, 2016 :
    PLEASE ANYONE WHO HAVE OPEN BETA 7 BUILD CAN PROVIDE THE APK OF FILE MANAGER.
    I ACTUALLY UNINSTALLED IT BY MISTAKE.
  14. fjvaz1995
    fjvaz1995 , Nov 17, 2016 :
    Initial impressions of the current update, clean flash with internal storage wiped, now using f2fs file system...
    Smooth as butter, animations ,recents everything is just smooth.
    Audio tuner is good.
    Notification LED bug is fixed, all notification light blink with same rate.
    Battery right now seems okay, waiting for two battery cycles to complete.
    No camera improvements yet, expecting a good results with the Android N update.
    Alert slider is still, messed up, don't know why and how it is working in that manner.
    WiFi seems to keep losing network,and tries to reconnect.
  15. danimartinez95
    danimartinez95 , Nov 17, 2016 :
    In the gestures section you can find the option to use three fingers also you can do it with the power button and the volume down at the same time
  16. Archies
    Ice Cream Sandwich Nov 17, 2016
  17. James Matthew Wells
    James Matthew Wells , Nov 17, 2016 :
    I am not sure if I just need to leave apps optimized with this now or to un-optimize. It sounds like this goes beyond normal doze so if I un-optimize then the apps would behave the same way as with normal doze. Am I correct in this assumption?
  18. morvael
    Eclair Nov 17, 2016
    morvael , Nov 17, 2016 :
    Too bad, that's what I expected. I hate finger swiping to make screenshots. Had this on my SGS4 and in some apps it was virtually impossible to make a screenshot using dedicated gesture. Most reliable method for me, is the CM method of screenshot via power menu. That way it makes the screenshot when nothing happens with the phone, so it's really reliable. Second best is pressing physical buttons. Gesture is worst possible method.
    patrickSVK and AcmE85 like this.
  19. danimartinez95
    This can't be added by OnePlus. You can download do it in the forum are some guides to do it. Google present the Assistant as a exclusive to Pixel's
    Archies likes this.
  20. Ricapitolando
    Eclair Nov 17, 2016
    Ricapitolando , Nov 17, 2016 :
    When I slide down the n.c., toggles doesn't work even if I extend the n.c. at all... Do you have this bug too?
