170
OxygenOS Open Beta 7 (MM) for OnePlus 3
Thread Status:
Not open for further replies.
  1. G_Flotts_Gryffin_FAee
    Cupcake Nov 17, 2016
  2. prisacariuadi
    Jelly Bean Nov 17, 2016
    prisacariuadi , Nov 17, 2016 :
    i had it on Beta 6 ROM.The behaviour was: drop down once, try to toggle...nothing happens, drop down twice, toggle works.
    since Beta 7 the toggles work.try to reflash...a clean one.
    Ricapitolando likes this.
  3. Dr_Superbot
  4. JelleZon
    Lollipop Nov 17, 2016
    JelleZon , Nov 17, 2016 :
    It feels great.
    Nougat is great :p
    No bugs so far.
    Battery Life is way more decent than oos beta (3.5.5).
  5. G_Tamilselvan_R_sYzU
    Honeycomb Nov 17, 2016
    G_Tamilselvan_R_sYzU , Nov 17, 2016 :
    Go to settings - apps- click settings icon on the top right corner - apps auto launch
  6. F_Nilesh_Sharma_NxRs
  7. tobias14
    Ice Cream Sandwich Nov 17, 2016
    tobias14 , Nov 17, 2016 :
    or you can hold power & vol down buttons simultaneously for screenshot
    otto2 and miikapk like this.
  8. Archies
    Galahad95 and andredias like this.
  9. simonone
    simonone , Nov 17, 2016 :
    Ah, who knows? Guess experimentation is needed, as there's nothing at all in the way of documentation. A much more detailed changelog would be helpful! My suspicion at present is that you either totally exclude an app from doze and hibernation kill, or you accept both happening.
  10. miikapk
    Donut Nov 17, 2016
    miikapk , Nov 17, 2016 :
    I would love a custom color picker!
  11. chandertalreja
    Gingerbread Nov 17, 2016
    chandertalreja , Nov 17, 2016 :
    hey ,, the contacts are appearing double wen u search in dialer .. i mean each contact is showing up twice , its fine in contacts app but go to dialer and using the keypad search for a number and its appearing twice of each ... any way to fix that ?
  12. simonone
    That's not background freezing - it's in settings/battery>menu/aggressive doze & app hibernation
    G_Tamilselvan_R_sYzU likes this.
  13. simonone
    Not doing that for me - once only in contacts and in dialler. Check in dialler settings/contacts display what sources you have enabled for showing contacts
  14. James Matthew Wells
    James Matthew Wells , Nov 17, 2016 :
    Yea, I am going to experiment. I un-optimized the apps I care about getting notifications from in this setting as well as Nova Launcher (though it does not seem to be affected either way) to see what happens.
  15. purush789
  16. Archies
    G_Radek_Breś_XRCV likes this.
  17. alwayswynne
    alwayswynne , Nov 17, 2016 :
    After trial and error, I successfully installed the update. I love it. Its smooth, battery life seems on par with 3.2.7. Doze mode works well and RAM management seems to have improved as previously on stock 3.2.7, I got 3.8GB free, now I get 4.5GB free. Bluetooth also works and status bar toggles also work. If you actually do a full wipe after installation, it would remove some of the issues people are facing. Also able to load 4 games without background crashing too.
    The only wish I have is that the OnePlus 3T wallpapers were imported. No issue though as I can download them.
  18. alwayswynne
    Wipe data and cache after installation of CB 3.5.5 Beta 7. It will abolish your issues.
  19. InfernoK
  20. GANAPATHI 72
    Froyo Nov 17, 2016
    GANAPATHI 72 , Nov 17, 2016 :
    Hi friends,
    If will update manually we face any problem in my oneplus 3. Caz this is not official.
