170
OxygenOS Open Beta 7 (MM) for OnePlus 3
Thread Status:
Not open for further replies.
  1. Crussader
    Eclair Nov 17, 2016
    Crussader , Nov 17, 2016 :
    Yes... I had that as well when changing DPI ( build.prop edit )
  2. danimartinez95
    Gingerbread Nov 17, 2016
    purush789 likes this.
  3. gajdosma
    Cupcake Nov 17, 2016
    gajdosma , Nov 17, 2016 :
    Hi, i have installed open beta 6 with root and modified TWRP. Today installed OTA beta 7, after reboot, message instal failed. New OTA is already full update 1,41GB, and after reboot, my root access is denied. What is the correct procedure to update?
    Thanks.
  4. RossThompson96
    Honeycomb Nov 17, 2016
    RossThompson96 , Nov 17, 2016 :
    It's a shitty basic one which messes with music apps
  5. jmarcosk
    jmarcosk , Nov 17, 2016 :
    I know, but, I would like a way to only exclude a app of the task killer, not from Doze, but, right now it is excluding both.
    I also doesn't see any reason for a task killer on a 6GB ram phone.
  6. simonone
    simonone , Nov 17, 2016 :
    App hibernation (not actually the same as a task killer) is presumably aimed at battery saving not memory saving. I agree it would be good to choose which of doze and hibernation to apply to any app, rather than both or none, which the new feature seems to be
    Mightyhog likes this.
  7. morvael
    Eclair Nov 17, 2016
    morvael , Nov 17, 2016 :
    Seems like this no longer works, only 3 finger swipe.
  8. captive
    Donut Nov 17, 2016
    captive , Nov 17, 2016 :
    i tried even to uninstall some system apps, but it looks like system partition is unwriteable
  9. PAPZI1957
  10. BugdroidNerd
    BugdroidNerd , Nov 17, 2016 :
    At first I was like beta 7? As in Android 7 Nougat? Then I saw that it was only MM. :-(
  11. prisacariuadi
    Jelly Bean Nov 17, 2016
    prisacariuadi , Nov 17, 2016 :
    1. u can update as u did and install TWRP and SuperSU after
    2. u download the update from official page, via chrome(not from OOS Updater) and flash it via TWRP, wiping cache and installing Super SU after...you choose if you go dirty or clean
  12. katheria09
    Ice Cream Sandwich Nov 17, 2016
    katheria09 , Nov 17, 2016 :
    Double press power button for camera not working and option is missing in button section.
  13. katheria09
    Both 3 fingers and normal screeshot working for me.
  14. amolsapre1
    amolsapre1 , Nov 17, 2016 :
    The battery usage seems to have optimised a lot. usually by this hour, i am down to 15% with around the same SOT on 3.5.5. Other parameters like 4G signal, usage and settings remaining the same, I definitely feel the battery will be great if I use Wifi and tweak the settings. Also the android system and OS usage has significantly reduced. used to be almost equal to the screen usage.
    Sahilkum likes this.
  15. prisacariuadi
    nope...i just tried and works perfectly
  16. simonone
    Option is there for me, and double press continues to work to activate camera
    katheria09 likes this.
  17. pvsuru
    Eclair Nov 17, 2016
    pvsuru , Nov 17, 2016 :
    Hey, OxygenOS is becoming rich in features day by day.
    When will you implement most awaited call recording feature?
    AppLocker is using same password / pattern as of phone lock password / pattern, both should be different.
  18. Anim89
    Anim89 , Nov 17, 2016 :
    For some reason my minimal ADB n fastboot isn't reading the downloaded file. Can anyone help with that? I just flashed open beta 6 today morning using my computer.
  19. tijmen234
    tijmen234 , Nov 17, 2016 :
    Yes. A lot better in stand by. Not so much SOT inprovements.
  20. drashwanikoul
    Eclair Nov 17, 2016
    drashwanikoul , Nov 17, 2016 :
    Any comment of the photo/video quality compared to the stable OOS 3.2.7.
    Some mentions that 3.5.5, camera was worse.
    How is it on beta 7 compared to stable3.2.7?
