170
OxygenOS Open Beta 7 (MM) for OnePlus 3
Thread Status:
Not open for further replies.
  1. Archies
    Ice Cream Sandwich Nov 18, 2016
    Archies , Nov 18, 2016 :
    Right
  2. Archies
    Yes op please release CB officialy
  3. vijaysuryaj.95
    Eclair Nov 18, 2016
  4. Crussader
    Eclair Nov 18, 2016
  5. Nitheesh Reddy M
    Honeycomb Nov 18, 2016
  6. vijaysuryaj.95
    Eclair Nov 18, 2016
    vijaysuryaj.95 , Nov 18, 2016 :
    Might be on 22 nd of nov, official release may come out to op3 users along with the 3T
  7. Vishal_pipal
    Froyo Nov 18, 2016
    Vishal_pipal , Nov 18, 2016 :
    For me double press power button to open camera isn't working? Can anyone else confirm it?
    mithunmuthanna99 likes this.
  8. luthnice
    Froyo Nov 18, 2016
  9. sneakerspark
    Gingerbread Nov 18, 2016
  10. Bigbabba
    Froyo Nov 18, 2016
    York_21 likes this.
  11. G_libero_balsamo_rpTD
    Eclair Nov 18, 2016
    G_libero_balsamo_rpTD , Nov 18, 2016 :
    If you're talking about how to switch from twrp to stock recovery.... Usually I've opposite problem. When I flash new CB release, I have to reflash twrp as image before to reboot system, to avoid that twrp will be replaced by stock rec. Yesterday I did lose again twrp at third flash. HTH
    Crussader likes this.
  12. sahirhussain
  13. niclas.olsson
    Cupcake Nov 18, 2016
    niclas.olsson , Nov 18, 2016 :
    I've had that same problem with the previous one. Hoped this build would fix that, but apparently not...shame. Had nothing but trouble when using headset on my OP3!
  14. Hawkiinz
  15. sahirhussain
    sahirhussain , Nov 18, 2016 :
    not working for me either.
    Vishal_pipal likes this.
  16. jitheshkt
    Donut Nov 18, 2016
    jitheshkt , Nov 18, 2016 :
    Kinda off topic here : I hope playing with density makes these tiles like this or is there any fix ?
  17. prisacariuadi
    Jelly Bean Nov 18, 2016
    prisacariuadi , Nov 18, 2016 :
    it's impossible to select lte only because when you're outside LTE are will happen what?no signal?
    if u select LTE you will be able to connect also to 3g and 2g
    if u select 3g you will be able to connect also to 2g but no LTE
  18. simonone
    simonone , Nov 18, 2016 :
    I'm pretty sure you're right that this is the cause - as it is also the cause of 'frozen' widgets. But as the solution is a simple settings adjustment, I don't think I see this as a bug. The aggressive doze & hibernation is doing some great work on battery conservation - it just needs to be configured to not affect apps that you actually want to run all the time in the background. I'm not sure the best way to configure this for new users when this is not a beta - should all apps be included or excluded as default? Guess OnePlus would welcome feedback on this. Fundamentally, I think it's a good addition to the ROM.
  19. bhagyabharadwaj
    Froyo Nov 18, 2016
  20. anurag181294
    anurag181294 , Nov 18, 2016 :
    Disasterous battery backup.
    Seriously? Why can't you give us stable battery backup?
    It's high time op3 starts working on stock frequently. CB is feature rich but unusable. Seriously?
