170
OxygenOS Open Beta 7 (MM) for OnePlus 3
Thread Status:
Not open for further replies.
  1. simonone
    Honeycomb Nov 21, 2016
    simonone , Nov 21, 2016 :
    No one knows yet. We shall all have to wait and see
    otto2 likes this.
  2. li0r
    Donut Nov 21, 2016
    li0r , Nov 21, 2016 :
    thanks :) it help
    nitramcek likes this.
  3. fxguru77
    Jelly Bean Nov 21, 2016
    fxguru77 , Nov 21, 2016 :
    Yes just keep pressing on the update button
  4. fxguru77
    Yes you should try to disable doze for those apps in the battery settings
  5. nitramcek
    Ice Cream Sandwich Nov 21, 2016
    nitramcek , Nov 21, 2016 :
    Yeah "un-doze" Will work.
  6. AarKay2311
    Froyo Nov 21, 2016
  7. bhagyabharadwaj
    Froyo Nov 21, 2016
    bhagyabharadwaj , Nov 21, 2016 :
    The same problem is also occurring to me
    dp76 likes this.
  8. morvael
    Eclair Nov 21, 2016
    morvael , Nov 21, 2016 :
    Had my first random restart on OP3, in the middle of writing a Hangounts message. There is no /proc/last_kmesg. How may I know what happened?
  9. G_Pierre_Blasco_hkTx
    Cupcake Nov 21, 2016
  10. linqan
    Froyo Nov 21, 2016
  11. MartijnHeuvink
    Gingerbread Nov 21, 2016
  12. G_BMWKante_vKip
    Donut Nov 21, 2016
    G_BMWKante_vKip , Nov 21, 2016 :
    Deactivate scanning always available in the Advanced WLAN options. Me too had this Problem. It seems the new google play Services 10.0.84 have to do with this
  13. Alpha Mike Foxtrot
    KitKat Nov 21, 2016
    Alpha Mike Foxtrot , Nov 21, 2016 :
    Yes. In theory, however, there have been multiple cases of bugs after OTA. So the best method would be to install the file from the website and flash it manually and then clear cache.
    otto2 likes this.
  14. otto2
    Photography Expert Nov 21, 2016
    simonone likes this.
  15. Aryan001
  16. Intruder71
    Lollipop Nov 21, 2016
    Intruder71 , Nov 21, 2016 :
    No its not the best bet is full wipe then install it, I won't be dirty flashing...
  17. mtbgus
    mtbgus , Nov 21, 2016 :
    I want Nougat Beta and I want it now so I can start complaining about all the bugs it has in it. Zzzzzzzzzz :)
    Intruder71 and Desejmon like this.
  18. EpicLPer
    EpicLPer , Nov 21, 2016 :
    Hm, with the Open Beta 7 it seems that Magisk + SuperSU + XPosed won't work anymore? I'm always running into a bootloop when trying so...
  19. Wackencorpse
    KitKat Nov 21, 2016
    Wackencorpse , Nov 21, 2016 :
    SuperSU is working without problems. XPosed is causing the bootloops. Try to use this XPosed Version. It should work fine. Can't test it by myself because I am not able to install XPosed. Failure "not enough space"
  20. EpicLPer
    I'm using the Magisk module XPosed, not the directly flashable one.
