170
OxygenOS Open Beta 7 (MM) for OnePlus 3
Thread Status:
Not open for further replies.
  1. Anim89
    Gingerbread Nov 24, 2016
    Anim89 , Nov 24, 2016 :
    I'm wondering the logic behind this #thinkingdeeply
    MaitiuB likes this.
  2. Jdickie23
    Jdickie23 , Nov 24, 2016 :
    Another option would be to turn doze off completely in the developer options.
  3. jmarcosk
    jmarcosk , Nov 24, 2016 :
    I really hope that you are right!
  4. mstella
    Froyo Nov 24, 2016
    mstella , Nov 24, 2016 :
    I searched the topic, but I couldn't find the answer. In order to format the file system to F2FS, what should be done exactly? Going to system and formatting? Going to recovery menu and clearing data and cache? And then what, will there appear something when booting back up to choose the file system's format?
    Thanks for the help
  5. fjvaz1995
    fjvaz1995 , Nov 24, 2016 :
    Factory reset with internal storage wiped, u can do it from the reset option in settings, just select erase internal storage option and the phone will be wiped, and upon booting u will be booted onto f2fs format.
    Use diskinfo app to confirm
    otto2 likes this.
  6. Shivam Bhatia
    Donut Nov 24, 2016
  7. otto2
    Photography Expert Nov 24, 2016
    otto2 , Nov 24, 2016 :
    N,why should they do that? OP3 is still best Bang for Buck.
    ironass and instarobuk like this.
  8. Busjen
    Ice Cream Sandwich Nov 24, 2016
    Busjen , Nov 24, 2016 :
    Yes, i have this problem, i had same problem in the four last beta release. I have now got back to 3.2.7 and i have no problem med sms.
  9. L0cke
    L0cke , Nov 24, 2016 :
    Is the OnePlus Launcher choppy when scrolling, and with the animations for anyone else? Everything else is fine just that Launcher.
  10. L0cke
    Hmmm, I'm also getting the same on Action Launcher, but not Nova. Have cleared all caches.
  11. mstella
    Froyo Nov 24, 2016
    Thank you very much for the information. :) Was not aware that is was automatically formatted to f2fs upon new boot. Cheers!
    otto2 and fjvaz1995 like this.
  12. ssaikiran92
    Honeycomb Nov 25, 2016
    ssaikiran92 , Nov 25, 2016 :
    I don't think so. We should follow the update rules. We can get next beta only by next week. ~2 weeks after last beta.
  13. raja.d
    Ice Cream Sandwich Nov 25, 2016
    raja.d , Nov 25, 2016 :
    Not always buddy... Difference between
    CB beta 1 and CB beta 2 only 8 Days gap.....
    otto2 likes this.
  14. Archies
    Archies , Nov 25, 2016 :
    So where is update? :v
  15. G_thepixelcrafter88_iOla
    Froyo Nov 25, 2016
  16. danimartinez95
    Gingerbread Nov 25, 2016
    danimartinez95 , Nov 25, 2016 :
    Wait it should be available on Monday.
  17. Archies
    @Tony L. we are ready to take off :v :D
    NOUGAT <3
  18. FahimIslam
    FahimIslam , Nov 25, 2016 :
    Using this beta and currently it is giving me 9 hours of SOT !! Just want to say hats off ! Having some little issues with the apps but I am really happy with the current battery life :)
    otto2 likes this.
  19. Anim89
    Anim89 , Nov 25, 2016 :
    9 hours? How? That's more than double of mine :p
  20. Anim89
    markon101 likes this.
