208
OxygenOS Open Beta 8 for the OnePlus 7 and OnePlus 7 Pro
  1. pavanpv9
    Froyo Feb 13, 2020
  2. Batman360
    OnePlus Accessory Tester Feb 13, 2020
  3. Butch_Sales_ES
    Gingerbread Feb 13, 2020
    Butch_Sales_ES , via OnePlus 7 Pro , Feb 13, 2020 :
    Ahahaha an update for fixing one hand mode for dial.... And which I don't get, we don't usually used one hand mode for dial app, or even for browsing or contacts... Either way.... The solution for this is.... REMOVE THE ONE HAND MODE!, THERE ALL FIX lol
  4. Butch_Sales_ES
  5. BlueSwede
    Froyo Feb 13, 2020
    BlueSwede , Feb 13, 2020 :
    it's not possible to downgrade.
    if you want to do that you'd have to rollback to stable, which would wipe your phone, and then use local upgrade to install OB8.
    I don't like the OnePlus stock wallpapers and previously I could just go into settings and uninstall the OPWallpaperResources app.
    now not only have they removed the option to uninstall, but also installed them as a system app in the "reserved" root folder, which makes it impossible to uninstall even using ADB.. once I reboot, the system will download the apk from the reserved folder and reinstall it.
    there goes 165MB of wasted space. I hate it when OEMs do that..
    at least give us options, OnePlus.
  6. Butch_Sales_ES
    Oh bummer [e]1f614[/e]
  7. ThorEgil
    Eclair Feb 13, 2020
    ThorEgil , Feb 13, 2020 :
    It's a beta track. Features come and go.
    rarog likes this.
  8. Batman360
    Batman360 , via OnePlus 7 Pro Nebula Blue , Feb 13, 2020 :
    I'm aware but it's beta doesn't mean they remove zen more too just for the sake of it...bith of them were some useful features and override dark mode was Google's update removing them doesn't make sense
  9. Franzie3
    Froyo Feb 13, 2020
    Franzie3 , Feb 13, 2020 :
    i guess everyone can stop complaining now right....?? or are we already asking for beta 10?
    /s
  10. Pa1KumarM
  11. GraveDigger176
    nashu@123 likes this.
  12. jmvolfan
    Cupcake Feb 13, 2020
    jmvolfan , via OnePlus 7 Pro , Feb 13, 2020 :
    I upgraded to beta 9 and it seems the battery drain problem I was experiencing with beta 8 has been addressed. My phone is running noticably cooler as well compared to how hot it would get with normal use. I want to run it through a few battery cycles and be sure but so far it seems much better.
    venkyred20052 and Vivek_SV like this.
  13. nashu@123
    Froyo Feb 13, 2020
  14. emile29000
  15. DanielSun1981
    Eclair Feb 13, 2020
  16. akks
    KitKat Feb 13, 2020
    VaibhavBhargava and fidus62 like this.
  17. venkateshwaran
    venkateshwaran , Feb 13, 2020 :
    3 improvements asap in OnePlus 7
    1.low unclear in call volume levels and call quality when compared to Samsung Apple in noisy environments.need to be louder,richer, clearer.
    2. Upgrade quality of images,video of both cameras.
    3. Overall system Stability needs to be improvised. Auto brightness needs recalibration as in dim conditions it doesn't brightens up the display adequately feels sluggish while doing that.
    4. Need options for turning off and On Dolby Atmos for calls etc or whole system.
    5. Notifications clear all button should be displayed at last not at the beginning or start of the notifications.its annoying to reach the top isn't it.
    Kudos for developers and users who are rocking the OnePlus devices[e]1f525[/e]
  18. T1556225638986
