208
OxygenOS Open Beta 8 for the OnePlus 7 and OnePlus 7 Pro
  1. jmvolfan
    Cupcake Feb 13, 2020
    jmvolfan , via OnePlus 7 Pro , Feb 13, 2020 :
    I upgraded to beta 9 and it seems the battery drain problem I was experiencing with beta 8 has been addressed. My phone is running noticably cooler as well compared to how hot it would get with normal use. I want to run it through a few battery cycles and be sure but so far it seems much better.
    venkyred20052 and Vivek_SV like this.
  2. nashu@123
    Froyo Feb 13, 2020
  3. emile29000
  4. DanielSun1981
    Donut Feb 13, 2020
  5. akks
    Jelly Bean Feb 13, 2020
    VaibhavBhargava and fidus62 like this.
  6. venkateshwaran
    venkateshwaran , Feb 13, 2020 :
    3 improvements asap in OnePlus 7
    1.low unclear in call volume levels and call quality when compared to Samsung Apple in noisy environments.need to be louder,richer, clearer.
    2. Upgrade quality of images,video of both cameras.
    3. Overall system Stability needs to be improvised. Auto brightness needs recalibration as in dim conditions it doesn't brightens up the display adequately feels sluggish while doing that.
    4. Need options for turning off and On Dolby Atmos for calls etc or whole system.
    5. Notifications clear all button should be displayed at last not at the beginning or start of the notifications.its annoying to reach the top isn't it.
    Kudos for developers and users who are rocking the OnePlus devices[e]1f525[/e]
  7. T1556225638986
  8. rarog
    Lollipop Moderator Feb 14, 2020
    rarog , Feb 14, 2020 :
    Did you install any beta before? Do you know what differentiates beta from stable software, which comes preinstalled on OnePlus phones?
  9. T1556225638986
    Cupcake Feb 14, 2020
    T1556225638986 , via OnePlus 7 Pro , Feb 14, 2020 :
    I don't install beta before
  10. rarog
    Then you can't get automatic update to next beta.
  11. c3drik67
    Gingerbread Feb 14, 2020
    c3drik67 , Feb 14, 2020 :
    how would you expect her to come on your phone if you are not on beta build?
    with the holy spirit?
  12. T1556225638986
  13. c3drik67
    download the full beta rom and install manually.
    found on Official oneplus website.
    Download the software build for your device on this page. Please back up your data before flashing your device.
    Plug your phone into your computer and copy the downloaded .zip to your phone’s storage. If you’re using a Mac, you can install Android File Transfer Android File Transfer for this operation.
    After the .zip file is copied to your phone, go to 'Settings' - 'system update', click the 'settings' icon on the top right corner, choose 'Local upgrade', find the .zip file and click on 'Install' to confirm.
    The update takes about a minute (depending upon the file size), once done reboot your device to boot into the latest Oxygen OS.
    2 second to found it with google :-(
  14. Butch_Sales_ES
    Eclair Feb 14, 2020
    Butch_Sales_ES , via OnePlus 7 Pro , Feb 14, 2020 :
    Hey can I ask you, Regarding on your full update rather than... Incremental one, the onehand mode doesn't disappear? Could you confirm this?
    Thanks
  15. c3drik67
    i don't use it but he as disappear in the menu.
  16. T1556225638986
  17. T1556225638986
    why OnePlus company work like this ? if any update coming send the notification same time to OnePlus user's like a IOS update why OnePlus can't do that? then why we install the additional beta version or local update we increment update.
  18. Atanu Maji
    Gingerbread Feb 16, 2020
    Jagadeesan Annamalai likes this.
  19. Swejuggalo
    KitKat Feb 16, 2020
  20. G_Ankit_Shah_xtNg
    Eclair Feb 17, 2020
    G_Ankit_Shah_xtNg , via OnePlus 7 , Feb 17, 2020 :
    Hi,
    My (unasked) advice to OnePlus:
    1) If possible, seperate Google security patch and new OnePlus features update. A lot of people will stay calm because of this change
    2) Camera - This area needs substantial improvement. Often a ₹10,000 phone clicks better image than OnePlus 7
    3) Stage rollout - If it's essential, decrease the time taken from first device to last device at best. After being in beta for 2 months, a wait of 15 days for stagged rollout is way too much.
    I have no idea about how bugs are created and fixed, but one of the reason I bought OnePlus was that it hears it's community.
    Hope OnePlus and China recovers quickly from coronavirus and keep up the good work!
