208
OxygenOS Open Beta 8 for the OnePlus 7 and OnePlus 7 Pro
  1. GraveDigger176
    Gingerbread Feb 20, 2020
    stavros67 likes this.
  2. nashu@123
    Froyo Feb 20, 2020
  3. Azzlan
    Donut Feb 21, 2020
  4. N1578585402112
    Cupcake Feb 21, 2020
    N1578585402112 , via OnePlus 7 , Feb 21, 2020 :
    Just received the
    beta 9 update and have to say initial use seems to have better battery optimization than the 8 which was draining my battery. Am happy again
    Shajahankm likes this.
  5. FZ.
    Froyo Feb 21, 2020
    FZ. , via OnePlus 7 Pro , Feb 21, 2020 :
    I'm sure someone else already reported this, but I'd like to join the complaints on something that I consider quite indecorous from 1+
    Every time I unlock the phone in daylight I have to wait 3 seconds before I can see anything on the screen, it gives the impression that I have a cheap phone in my hand. The same thing was happening in the previous beta.
    I think that's something that should be addressed right away.
    Together with another thing: whatsapp audio that stops while listening to it with the phone at the ear. Very very annoying.
    Please!
  6. anik347
    Cupcake Feb 25, 2020
    anik347 , via OnePlus 7 , Feb 25, 2020 :
    i can't install the beta version from stable . In local upgrade if i tap on this file i got a massage like this picture . how can i install it ?
  7. N1566749324723
    Cupcake Mar 1, 2020
    N1566749324723 , via OnePlus 7 Pro , Mar 1, 2020 :
    how to roll back to stable bro
  8. SuppNyUs
    Honeycomb Mar 11, 2020
    SuppNyUs , via OnePlus 7 Pro , Mar 11, 2020 :
    I am not running a custom ROM anymore, but I can highly recommend you Havoc OS 3.3 and Evo X 4.1 :p
  9. Last edited by a moderator: Mar 11, 2020
  10. SuppNyUs likes this.
  11. A1577984888388
    Cupcake Mar 16, 2020
  12. Nithinfernandes
    OnePlus Bug Hunter Staff Member Mar 18, 2020
    Nithinfernandes , Mar 18, 2020 :
    Simple steps to submit feedback :
    1. Log into Community app
    2. Sign up with your OnePlus account.
    3. Look out for the "+" symbol and tap on it.
    4. Click on Feedback option.
    5. Select the issue category and answer the related questions
    6. At the end of the page click on Start recording to generate logs.
    7. Minimize the app and reproduce the issue and take screenshot at the time of occurrence.
    8. Go back to the app and stop recording.
    9. Finally click on "Submit " to share the log files.
    Note :
    After sharing the feedback, please delete the Oem_log file and folder from your Device in the File manager or it will occupy more Storage Space.
  13. Nithinfernandes
  14. H@ppyj@ri
    Donut Apr 19, 2020
  15. H@ppyj@ri
    Donut Apr 19, 2020
  16. Atanu Maji
    Honeycomb Apr 21, 2020
    Atanu Maji , via OnePlus 7 , Apr 21, 2020 :
    On OOS 10.3.2 and faced the same issue. Wiping cache from recovery would help.
  17. D3NIEL
    Cupcake Apr 24, 2020
    D3NIEL , Apr 24, 2020 :
    Why OnePlus, WHY do you have to remove every good feature you make?
    OnePlus_dude likes this.
