208
OxygenOS Open Beta 8 for the OnePlus 7 and OnePlus 7 Pro
  1. Artemus.
    Nougat Jun 29, 2020
    Artemus. , Jun 29, 2020 :
    Manually update...
  2. iamPhinnyJT
    Donut Jun 29, 2020
    iamPhinnyJT , via OnePlus 7 Pro , Jun 29, 2020 :
    Yes, Manual update can be done however previously if you roll back, then you can still get OTA now it is stopped, even if you update to 10.0.3 then it will still not show 10.3.3, again manually you have to download and install.
  3. naikjeevan
    Gingerbread Jul 1, 2020
    naikjeevan , via OnePlus 7 Pro , Jul 1, 2020 :
    I have done the full downgrade a couple of times didn't face any issue yet. I get regular updates. The new update is available as soon my phone turns on after downgrade. U must have done something wrong. Get the downgrade for your phone model from the beta 1 thread.
  4. iamPhinnyJT
    Donut Jul 2, 2020
    iamPhinnyJT , via OnePlus 7 Pro , Jul 2, 2020 :
    Could you please let me if you have tried Open Beta 15 and then downgrade back to Pie and get OTA to stable?
    Because, when I have rolled back from Open Beta 15 to Pie that is when it stopped giving OTA.
  5. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 2, 2020 :
    The OTA should come. But of somewhat reason it don't
    You will need to upgrade in steps. You can't go from Pie to latest 10 directly. For a International build you need 10.0.3 before 10.3.3. On EU you need 10.0.2 or possible 10.0.3 (not totally sure). Any older version works too.
    You may also want to use a recent post not something that is this old...
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-pro-and-oneplus-7.1232394/
  6. iamPhinnyJT
    Donut Jul 3, 2020
    iamPhinnyJT , via OnePlus 7 Pro , Jul 3, 2020 :
    Yes, so how i also did, downgrade to pie from Open Beta 15, then it did not show OTA, used Oxygen Updater and updated to 10.0.3.
    Still there was no OTA after 10.0.3, then again used Oxygen Updater and updated to 10.3.3.
    However there is some issue, because when i have rolled back to Pie, the Play store Apps where downloading very slow like in 100Kb(30 min download speed)... but when I switched ON the VPN, it gives great Internet speed.
    However, VPN also does not show OTA.... there is some issue.
    sai- nath-8099 likes this.
  7. A1577984888388
    Cupcake Jul 27, 2020
    DAMZONE likes this.
  8. akks
    KitKat Jul 27, 2020
    akks , Jul 27, 2020 :
    When did you flash this build? Did you update?
  9. iamPhinnyJT
    Donut Jul 30, 2020
    iamPhinnyJT , via OnePlus 7 Pro , Jul 30, 2020 :
    Issue is resolved now OTA is working...
  10. DAMZONE
    Donut Jul 31, 2020
    DAMZONE , via OnePlus 7 , Jul 31, 2020 :
    I'm using OnePlus 7. Sometimes I feel my mobile is like hanging. But from last few months I feel some bug in galary app coz when I try to zoom in photos it's hardly zoom in. Like some glitches. Photos automatically zoom in and zoom out. And the new issue I catch from the last few days that is hanging problem. I don't know why but some apps not open quickly or its showing the app is opening but that's not.
  11. C1570284905481
    Cupcake Aug 8, 2020
  12. Rajat_142
    Eclair Aug 8, 2020
    C1570284905481 and ShigBammy like this.
  13. DAMZONE
    Donut Aug 9, 2020
    DAMZONE , via OnePlus 7 , Aug 9, 2020 :
    Form few days I saw there is something in my display on the upper left hand side showing a circle and there is something in the circle, I was thinking something happened with my phone's display but now i checked my display very closely. And its very unexpected . The circle in my display and there is a bag in that circle and when i know what was that.... i again checked on the upper right hand side.. there is showing me " Alive ** , Killed **[e]1f602[/e][e]1f602[/e][e]1f602[/e]. What is this????.... How pubg screen showing me on the display???. How to remove this.... Plz help me.
  14. sai- nath-8099
    Cupcake Aug 10, 2020
    sai- nath-8099 , via OnePlus 7 , Aug 10, 2020 :
    Hi friend please format format u phone
  15. F1591272564568
    Cupcake Aug 29, 2020
  16. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 29, 2020 :
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-pro-and-oneplus-7.1269796/
    Read post 1505. I provided the files needed for International version. The last step is only needed if you need 10.3.3 though. If you want the latest one it should be enough to just update from 10.0.3 via OTA. If you don't get it I think it should be available via Oneplus homepage at Support, Software Updates.
    Same rollback for EU device but different update files. Keep in mind that the rollback is International. If you need EU don't update via OTA because you end up on International firmware.
