208
OxygenOS Open Beta 8 for the OnePlus 7 and OnePlus 7 Pro
  1. #41
  2. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 3, 2020 :
    I see people complaining on drain every single update. And at the same time people saying battery life is great. On same device model...
    Some would need to investigate why and some just needs to let it settle in rather than constantly wiping cache and stuff and actually prolong the issue.
    #42
    femiuex, Johan Notte and the_reckoner like this.
  3. #43
  4. gianluigino
    Donut Jan 3, 2020
    gianluigino , Jan 3, 2020 :
    ah here, last update I had an empty phone, so I have a hard reset directly, now I have some stuff, how do you do a wipe cache but without twrp? obviously I would not want to lose files
    #44
  5. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 3, 2020 :
    Wiping cache would be a last resort, not a standard procedure. If an app missbehaves just wipe the app cache or the app data. Wiping all caches should not really be needed.
    However...
    https://support.t-mobile.com/docs/DOC-40182
    But I'm not so sure it really does much. There is no cache partion anymore. Full cache wipe just forces the phone rebuild the cache and drain battery while doing so
    And cleaning apps like SD Maid exists. It can press all wipe cache buttons for all apps automatically for you 🙂
    #45
    G1576777582182 likes this.
  6. vishrutkmr7
    Honeycomb Jan 3, 2020
    vishrutkmr7 , Jan 3, 2020 :
    One-Handed Mode is probably named wrong. It should be like "Reachability Mode" in iOS
    The general perception about "One-Handed Mode" is that it'll shrink the whole screen contents to a manageable size and put it on a corner of the user's choice (like in GBoard from Google), probably that's what you were expecting, right?
    #46
  7. #47
    Nemish gupta likes this.
  8. gianluigino
    Donut Jan 3, 2020
    oh it's work. thank you very much. I'm downloading the update. let's see how is it. thanks again
    #48
  9. C1570672236177
    Eclair Jan 3, 2020
    #49
  10. Sid37
    Gingerbread Jan 3, 2020
    #50
    G_PAS0179_JrOp and techygeek like this.
  11. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 3, 2020 :
    Never been able to replicate.
    On all 5Ghz connections?
    If you haven't done so report it with the feedback tool.
    #51
  12. Vinoratheesh
    Froyo Jan 3, 2020
    #52
    roryrudy likes this.
  13. #53
    terr20114_2 likes this.
  14. Sopheak_Noun
    Froyo Jan 3, 2020
    #54
    kapilbhaskar23 likes this.
  15. Swejuggalo
    Lollipop Jan 3, 2020
    Swejuggalo , Jan 3, 2020 :
    Need to swipe near the edges of the screen without triggering a scroll. Try to flick not slow swipe.
    #55
    James McMorine and roryrudy like this.
  16. #56
  17. R_d_M
    #57
  18. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 3, 2020 :
    Seems like that bar is intended and also exists on the other navigation method
    #58
  19. R_d_M
    R_d_M , via OnePlus 7 Pro , Jan 3, 2020 :
    Unlikely.
    Because when i disable the hide option it messes up the space underneath the keyboard with wrong collor.
    #59
