208
OxygenOS Open Beta 8 for the OnePlus 7 and OnePlus 7 Pro
  1. F1567021011499
    Eclair Jan 11, 2020
    F1567021011499 , Jan 11, 2020 :
    why in one hand mode ?for some touches it is getting back for some touch it is not goin back...
    notification bar is goin back when reverted back to Normal mode from one hand
  2. Alex_Cerv and F1567021011499 like this.
  3. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 11, 2020 :
    The one handed mode is for scrolling and to be able to reach upper region with one hand. Opening stuff or writing triggers full screen. It's not a mode that will be permanent until you disable it.
    Alex_Cerv likes this.
  4. bilal659Iqbal
    Cupcake Jan 11, 2020
  5. P1568915505675
  6. Sopheak_Noun
    Froyo Jan 11, 2020
  7. Alex_Cerv likes this.
  8. Sopheak_Noun
    Froyo Jan 11, 2020
  9. Alex_Cerv likes this.
  10. Gangester
    Donut Jan 11, 2020
    Gangester , via OnePlus 7 Pro , Jan 11, 2020 :
    my battery life is worse then it was at OB 7
    I didn't have the black screen on 7 but now have it on 8
    one time the phone just shut down my WiFi and Bluetooth and after few seconds turn them on
    no internet connection sometimes but I'm not sure if it is because of the update or my router has a problem but I'm using the same router and internet when I was on OB 7 and I didn't have the problem even once, mostly it occurs when I'm using VPN which I use daily
    that the problems I had so far
    I'll post again if I notice anything else
    and I hope that these problems be solved on the next update :)
    hpruthi1 likes this.
  11. sahilkhan1998
  12. ferozarshad123
    ferozarshad123 , Jan 11, 2020 :
    hi, can you one day update the keyboard placement on the 7 Pro when using gestures from the bottom? there is this black bar at the bottom which can be troublesome for when you want to hit space but accidentally hit the black bar and make the keyboard go away. like I don't want to type some ADB code to fix the issue myself.
  13. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 11, 2020 :
    Official what? This is open beta. Stable updates is probably what you are using. You don't get beta updates a less you manually choose beta updates. And if you regret it it most often wipes your phone
  14. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 11, 2020 :
    The bar will stay as long as Android 10 exist and will probably long after too... Pressing the empty bar is not an issue with Swiftkey. And it should always follow keyboard theme. Does that for me in Swiftkey and for most others with Gboard. Toggle phone/keyboard themes or something. It should not be black unless keyboard theme is black
  15. G_Naveen_nani_ZOZi
    RaviJaya7 and Sagarshaikh like this.
  16. A1548213356834
  17. Alex_Cerv likes this.
  18. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 11, 2020 :
    Do you want to be a beta tester or do you think this is a update of 10.3.0/10.0.3?
    If you change to beta and regret it you will need to wipe the phone
    Sickchild72 and Alex_Cerv like this.
  19. hpruthi1
  20. Prasad.anu
    Prasad.anu , Jan 11, 2020 :
    kindly fix the debug that downloaded videos not playing in gallery and not able to send into WhatsApp status as it is showing file not supported error.
