208
OxygenOS Open Beta 8 for the OnePlus 7 and OnePlus 7 Pro
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jan 23, 2020
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 23, 2020 :
    Recently updated? Let it charge over night a few times and use the phone normally for some time. If you can pinpoint some apps or system components it would be helpful.
    Always good to post some informative screenshots
    OnePlusAim likes this.
  2. jmvolfan
    Cupcake Jan 23, 2020
    jmvolfan , via OnePlus 7 Pro , Jan 23, 2020 :
    I am also experiencing battery drain and the phone getting noticably hotter than on previous beta builds. I have charged my phone like I always had previously but instead of the battery lasting all day, I am lucky if it lasts 6 to 7 hours and that's with hardly any use. If I use my phone to browse the internet or watch Netflix the battery won't last more than an hour. I really hope the next update fixes this issue.
  3. Deactivated User
    Jan 23, 2020
    Deactivated User , Jan 23, 2020 :
    Did you report the bugs here?
    https://forums.oneplus.com/feedback/ - > Submit bug
  4. Shivdutt246
    Eclair Jan 23, 2020
    Shivdutt246 , Jan 23, 2020 :
    Instagram keeps crashing at launch after recent 2 updates.
    Issue is not frequent but happens once or twice a day. The app is either stuck on starting animation or crashes and closes itself.
    Mobile Network Coverage quality has dropped. Network drops to 2 bars at places where previously had full coverage. Mobile Data services crash at times while hotspot is turned on. The only fix right now is a quick toggle between flight mode on/off.
  5. stavros67
    Froyo Jan 23, 2020
  6. Shivdutt246 likes this.
  7. Shivdutt246
    Eclair Jan 23, 2020
    Gaming Bug - Speaker Issue
    While playing Pubg mobile, main audio volume quality decreases as soon as mic is turned on the communicate.
    Pubg mobile uses mic volume through call volume control and game audio through main media volume.
    I have tried and verified that the media volume quality decreases even when it is set to full as soon as you turn on mic to communicate. Once you turn off mic, volume quality restores to normal.
    Again, this issue is only while playing on speaker. Audio works fine when playing with headphones plugged in.
  8. Deactivated User
    Jan 23, 2020
  9. Byfeer10
    Donut Jan 23, 2020
  10. DRS2483
    DRS2483 , via OnePlus 7 , Jan 23, 2020 :
    Hi, I have Build# 10.3.0.GM57AA installed on my Oneplus 7. having peculiar issue with whatsapp notifications, as stated below:
    1. Put the phone in ‘vibrate’ mode
    2. And when you get whatsapp call from others, your phone does not vibrate, and just be like in silent mode.
    I tried modifying the whatsapp notification settings and all other settings, but nothing helped.
    Does anyone experienced the similar issue?
    And I am hopeful that it gets fixed in the latest build.
    Did anyone get a chance to verify in the latest build? I did not enrolled to the beta releases programs.
  11. prfraczek
    Ice Cream Sandwich Jan 24, 2020
    prfraczek , via OnePlus 7 Pro , Jan 24, 2020 :
    Did you see the subject of this thread?
  12. DRS2483
    Cupcake Jan 24, 2020
    DRS2483 , via OnePlus 7 , Jan 24, 2020 :
    Yes, here I am looking for help if some one can check if the same issue still there in this beta version or not. I have submitted the bug, as well for this.
    Deactivated User likes this.
  13. Chirag_Panchal
    Donut Jan 24, 2020
  14. OnePlusAim
    Honeycomb Jan 24, 2020
    OnePlusAim , via OnePlus 7 Pro , Jan 24, 2020 :
    what do you mean?
  15. Abeed7
    Abeed7 , Jan 24, 2020 :
    My alarm has been going off late often. For example, it went off 6 minutes late today in the morning. (Using beta 8 at the moment)
  16. Anaschauhan333333
    Anaschauhan333333 , via OnePlus 7 , Jan 24, 2020 :
    I am unable to downgrade from open beta 8 to stable oxygen os 10.3.0. In local upgrade following error occurs and in recovery mode there is no option to install from internal storage.
  17. aravinthin
    Froyo Jan 24, 2020
  18. Harjot1826
    Harjot1826 , via OnePlus 7 Pro , Jan 24, 2020 :
    use OnePlus 7 pro mobile. but no available latest software update.. December 12 security update India.. please date confirm update available. thanks you
