208
OxygenOS Open Beta 8 for the OnePlus 7 and OnePlus 7 Pro
  1. wasim9308
    Cupcake Jan 3, 2020
  2. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 3, 2020 :
    Then you will not get it. Betas is not an upgrade. You manually change update path. Going back to stable means full device wipe. And going beta could mean more bugs. Only use beta if you want to beta test and understand what it is all about.
    wasim9308 likes this.
  3. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 3, 2020 :
    If you want beta some day. Here is how.
    Download Beta 8. And flash it via local upgrade. The only thing to think about is that it needs to be of a newer date than already installed OS. If it's not you need to downgrade first via a downgrade file. Then beta 5 then upgrade from there. Both the rollback and return to stable will result in a wipe.
    Downgrade.
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-and-oneplus-7-pro.1099154/
    Sources of update downloads
    https://androidfilehost.com/?w=files&flid=296897
    https://swejuggalo.blogspot.com (torrent alternative)
    OnePlus[e]2122[/e]
    Everything OnePlus #NeverSettle
    Not endorsed by OnePlus
    https://t.me/OnePlus
    (open up with Telegram app)
    And the app Oxygen Updater by changing update path in settings.
    Alex_Cerv likes this.
  4. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 3, 2020 :
    Seems like community app changes and follows system settings...
    Notifications follow...
    Google play does not care though
    noobnoob25 likes this.
  5. amralomari
    Donut Jan 3, 2020
    amralomari , via OnePlus 7 Pro , Jan 3, 2020 :
    WoW
    I was just thinking if you can do something like this in android, my iPhone friend will switch to OP after me showing it to him lol
  6. Naz98
    Cupcake Jan 3, 2020
    Naz98 , via OnePlus 7 Pro , Jan 3, 2020 :
    This update has caused the Google Keyboard to be higher up on the screen and now the navigation bar that I don't want will not go away!
    dasacom likes this.
  7. Alex_Cerv
    Gingerbread Jan 3, 2020
    Alex_Cerv , Jan 3, 2020 :
    well if u cange devices of 700 euros just for BT earphones.... dunno guys... i am reading just lot of crap here!!!
    Firstly which model? have you tried them with a Samsung on Android 10 before writing here?
    I connect mine on the car and BT helmet earphones, no issues so far.
  8. rockinsnake
    Froyo Jan 3, 2020
  9. Bernest44
    Bernest44 , via OnePlus 7 Pro , Jan 3, 2020 :
    Ok...so I'm trying to find a bug. So far....this is damn good. I need to SEE something....I got nothing. Camera will always follow as I use it mostly on the weekends. I went from 10.3 to this. I'm very happy to have the December Android Update. I can only go as far as to say things are snappy...if that makes sense. But for me...most bugs are not always immediate. I am a BIG BIG fan of anyone asking for more One Plus FONTS! Never Settle!
  10. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 3, 2020 :
    For my usage it's great.
    For me it looks like this.
    Is it that bar you don't want or is that area white too?
    Bernest44 likes this.
  11. dasacom likes this.
  12. Bernest44
    If I may chime in...I saw a faster battery drain on 10.3. Been solid all day....but tonight is a true test. But for all the complaints and I'm flashed. My battery never really had any issues. Ive bounced from stable to beta a fair amount.
    Swejuggalo likes this.
  13. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 3, 2020 :
    Sticked with beta since beta 1. It can have a few rough edges sometimes but I prefer it over stable due to more updates and more... Well... Action. Makes it more fun
    AndiTheBassman and Bernest44 like this.
  14. Bernest44
    Nothing beats the rush of a new Beta or Update. There's alot worse things I could be doing. Lol. Ok...I do but I dial myself back in! [e]1f602[/e][e]1f602[/e]
  15. Ajikdevadas
    Froyo Jan 3, 2020
    Ajikdevadas , Jan 3, 2020 :
    what about these issues?
    1.battery drainage issue(which increased even more in 10.3.0 update
    2.unresponsive touch in the bottom part of the screen.
    3.automatic ending of certain apps.
    4.google assistant popup without even doing anything
    K1577326527695 likes this.
  16. PankajDayal9
    Cupcake Jan 4, 2020
    PankajDayal9 , Jan 4, 2020 :
    I am using oneplus 7pro with os 10.3.0 it's facing lot of issues.
    i m showing problem with this device for ex black display, camera problem, battery Darin
  17. C1567789324865
    Cupcake Jan 4, 2020
    Arun_Kashyap likes this.
  18. Ranjith@9596
    Donut Jan 4, 2020
