90
OxygenOS Open Beta 8 for the OnePlus 7T Pro and 7T
  1. oldusername
    Gingerbread Sep 19, 2020
    oldusername , via OnePlus 7T , Sep 19, 2020 :
    That was your ss in xda and telegram?
  2. KhairolSyawal
    Eclair Sep 20, 2020
    KhairolSyawal , via OnePlus 7T Pro , Sep 20, 2020 :
    Go check 1st beta 1 out . Read the info inside .
  3. N1580388597241
    Froyo Sep 20, 2020
    N1580388597241 , via OnePlus 7T , Sep 20, 2020 :
    Use oxygen updater app
  4. Erkki_Heiskanen
    Donut Sep 20, 2020
    geoxar and ssagheer like this.
  5. SohamMallick
    Gingerbread Sep 20, 2020
  6. KhairolSyawal
    Eclair Sep 20, 2020
    ananyr likes this.
  7. geoxar
    Honeycomb Sep 20, 2020
  8. Sravan1699
    Froyo Sep 20, 2020
    Sravan1699 , via OnePlus 7T , Sep 20, 2020 :
    Why there is no Stable Update for OnePlus 7T last update that rolled out that was Oxygen OS 10.3.4 in Aug,which had so many bugs especially the battery drain, looks like Stable updates are beta update this day. OnePlus really needs to step up & should focus on how Oxygen OS can be refined and not by adding new features
  9. saikiran666
    Eclair Sep 20, 2020
    saikiran666 , via OnePlus 7T , Sep 20, 2020 :
    Bro they dont care, they will just send the update when they were finished with nord and 8 series... I never thought that one plus will become some same product as samsung or MI. I think even they are far better.🤔🤔
    sravan donugari likes this.
  10. tarkzy
    tarkzy , Sep 20, 2020 :
    l posted a reply from OnePlus customer services in the twrp thread for 7t yes. That was a while back then they released the new beta OTA proving everything the OnePlus customer service agent said was BS. I also asked the developer of twrp for the 7t in his telegram thread if he thought OnePlus would be true to there word and fix the issue with decryption.
  11. oldusername
    oldusername , via OnePlus 7T , Sep 20, 2020 :
    Ah.....Ok. Do we know what other implications does this Android key store has on a phone like security or loopholes. We cannot just say fix it because of TWRP. Yeah, even I read Mauronofrio's reply....over your ss
  12. Antson Menachery , via OnePlus 7T , Sep 20, 2020 :
    Hi I'm a OP 7T user and earlier was using OP7. I generally has my Bluetooth devices like earphone and speakers connected at the same time. However many times while changing the device doesn't either through volume button or through Bluetooth settings doesn't work which is a major annoyance. Many times the audio completely stops to come in any of the connected devices.
  13. tarkzy
    Indeed but l think you will find other devices shipped with Android 10 like the Nord and 8 series don't have the keystore issue the 7t has. So saying it could be a security issue well l don't think so.
    pedritopl likes this.
  14. oldusername
    Well, I am not an expert on this particular area. 7T series has bad luck... I guess. If I could take it to the Twitter.... How?
  15. tarkzy
    Waste of time l have already posted they just ignore it.
  16. oldusername
  17. tarkzy
    Yes before it goes down that road need to know what exactly 100% is broken in keystore then pursue it change.org and whatever else is needed for them to listen.
    OmarRolon, Udit2508 and silverthooth like this.
  18. Z1535301018938
    Eclair Sep 21, 2020
    Lemillion likes this.
  19. Blessingspy
    Cupcake Sep 21, 2020
  20. bgreddy
    Donut Sep 21, 2020
